Re: Does my power of receiver match the power of the speaker needed?
Reply #2 –
Important thing first: if Jamo is what Jamo was back in the day, these can play loud enough music for a typical living room with a typical receiver.
* As DVDdoug writes, speaker rating indicates the maximum power handling capacity. Conventional wisdom says that if you want to use a 150 W amp on 120 W rated speakers, it means you cannot turn the knob all the way up.
* That is highly misleading though: without knowing the input signal, you cannot really infer output wattage from looking at the volume knob. And indeed if you use a smaller amp but drive it into clipping, it is easier to damage the speakers.
* As for the "240", I suspect that Jamo still rates their speakers to mean it is fitting for an amplifier up to 120 W RMS / 240 W peak.
