Following previous topic, I have created a contextual menu creator helper to easily add contextual menus to any panel.
Right now the usual method is creating this function
this.rbtn_up = (x, y) => {...}
And then adding manually menu entries with indexes. The main problem is later edits always require careful index checking, leaving holes for submenus, etc.
Also, every panel requires the same code. And multiple objects within the same panel require nested functions calls to append multiple menus.
A switch block is needed later to check the idx selected, so you must manually link the menu creation and the idx checking, losing even more time when coding it.
And lets not talk about changing the order of some entries at a menu once it has been already coded...
![](https://hydrogenaud.io/index.php?PHPSESSID=qa5l082e4p61cn8ukti3sgobgm&action=dlattach;attach=19240)
As a solution here is offered an alternative, where you simply add entries to a list and the menu is created automatically with their indexes calculated and linked to the right entries.
'use strict';
Contextual Menu helper v 1.0 18/03/21
Helper to create contextual menus on demand on panels without needing to create specific methods for
every script, calculate IDs, etc. Menus are pushed to a list and created automatically, linking the entries
to their idx without needing a 'switch' block or leaving holes to ensure idx get enough numbers to expand the script.
The main utility of this helper is greatly reducing coding for simple menus and having both, the menu logic creation
and the menus' functions on the same place. Creation order is done following entry/menus addition.
Methods:
_menu({bSupressDefaultMenu = true, idxInitial = 0})
-bSupressDefaultMenu: Suppress the default context menu. left shift + left windows key will bypass it.
-idxInitial: Specifies an initial idx to create menus (useful to concatenate multiple menus objects)
.btn_up(x, y, object)
-NOTE: Called within callbacks to create the menu. Specifying an object (like another menu instance), lets you
concatenate multiple menus. Uses object.btn_up() and object.btn_up_done()
.getMainMenuName()
-NOTE: Used to get the key of the main menu. Useful to concatenate multiple menus.
.newMenu(menuName)
-menuName: Specifies the menu name or submenus names.
-NOTE: Menu is called 'main' when it's called without an argument.
-NOTE: Every menu created after the first one (main menu) will be appended to the main menu.
.newEntry({entryText = null, func = null, menuName = menuArr[0], flags = MF_STRING})
-entryText: new menu entry text. Using 'sep' or 'separator' adds a dummy separator.
-func: function associated to that entry
-menuName: to which menu/submenu the entry is associated. Uses main menu when not specified
-flags: flags for the text
-NOTE: All arguments (but 'func') may be a variable or a function (evaluated when creating the menu)
.newCheckMenu(menuName, entryTextA, entryTextB, idxFunc)
-menuName: to which menu/submenu the check is associated
-entryTextA:From entry A (idx gets calculated automatically)
-entryTextB:To entry B (idx gets calculated automatically)
-idxFunc: Logic to calculate the offset. i.e. EntryA and EntryB differ by 5 options, idxFunc must return values between 0 and 5.
-NOTE: All arguments (but 'idxFunc') may be a variable or a function (evaluated when creating the menu)
For example:
-Standard menu:
var menu = new _menu();
menu.newEntry({entryText: 'Hola', func: () => {console.log('hola')}});
menu.newEntry({entryText: 'sep'});
menu.newEntry({entryText: 'Hola2', func: () => {console.log('hola2')}});
var bSubMenu = true;
const funct = () => {return (bSubMenu) ? 'SubMenu 1' : 'SubMenu 2';};
menu.newMenu(funct);
menu.newEntry({menuName: funct, entryText: 'Change SubMenu', func: () => {bSubMenu = !bSubMenu}});
menu.newEntry({menuName: funct, entryText:'Hola 3', func: () => {console.log('hola3')}, flags: () => {return (bSubMenu) ? MF_STRING : MF_GRAYED}});
menu.newCheckMenu(funct, 'Change SubMenu', 'Hola 3', () => {return (bSubMenu) ? 0 : 1;});
menu.newEntry({entryText: 'Hola 4', func: () => {console.log('hola4')}});
function on_mouse_rbtn_up(x, y) {return menu.btn_up(x, y);}
Renders to: (note 'Hola 4' Entry is drawn after the sub-menu)
+Hola
+HOla 2
+SubMenu 1 / SubMenu 2:
+Change SubMenu
+Hola 3
+Hola 4
- Manually adding some entries to the menu (uses previous code too):
var menuTwo = new _menuTwo();
function _menuTwo() {
this.idxInitial = 0;
this.btn_up = (idxInitial) => {
this.idxInitial = idxInitial;
const menuName = menu.getMainMenuName();
menu.getMenu(menuName).AppendMenuItem(MF_STRING, idxInitial + 1, 'Manual entry 1');
this.btn_up_done = (currIdx) => {
if (currIdx == this.idxInitial + 1) {
console.log('Manual entry 1');
return;
} else {return;}
function on_mouse_rbtn_up(x, y) {return menu.btn_up(x, y, menuTwo);}
Renders to:
+Hola
+HOla 2
+Change SubMenu
+Hola 3
+Hola 4
+Manual entry 1
include(fb.ComponentPath + 'docs\\Flags.js');
function _menu({bSupressDefaultMenu = true, idxInitial = 0} = {}) {
var menuArr = [];
var menuMap = new Map();
var entryArr = [];
var entryMap = new Map();
var idxMap = new Map();
var checkMenuMap = new Map();
var checkMenuArr = [];
var idx = idxInitial;
// To create new elements
this.newMenu = (menuName = 'main') => {
menuArr.push(menuName);
if (menuArr.length > 1) {entryArr.push({menuName: menuName, bIsMenu: true});}
return menuName;
this.newMenu(); // Default menu
this.newEntry = ({entryText = null, func = null, menuName = menuArr[0], flags = MF_STRING}) => {
entryArr.push({entryText: entryText, func: func, menuName: menuName, flags: flags, bIsMenu: false});
return entryArr[entryArr.length -1];
this.newCheckMenu = (menuName, entryTextA, entryTextB, idxFun) => {
checkMenuArr.push({menuName: menuName, entryTextA: entryTextA, entryTextB: entryTextB, idxFun: idxFun});
// Internal
this.getMenu = (menuName) => {return (!menuName) ? menuMap : menuMap.get(menuName);}
this.getIdx = (entryText) => {return (!entryText) ? entryMap : entryMap.get(entryText);}
this.getEntry = (idx) => {return (!idx) ? idxMap : idxMap.get(idx);}
this.getCheckMenu = (menuName) => {return (!menuName) ? checkMenuMap : checkMenuMap.get(menuName);}
// External
this.getNumEntries = () => {return entryArr.length;}
this.getMainMenuName = () => {return menuArr[0]}
this.createMenu = (menuName = menuArr[0]) => {
if (_isFunc(menuName)) {menuName = menuName();}
menuMap.set(menuName, window.CreatePopupMenu());
return menuMap.get(menuName);
this.addToMenu = ({entryText = null, func = null, menuName = menuArr[0], flags = MF_STRING}) => {
if (entryText == 'sep' || entryText == 'separator') {menuMap.get(menuName).AppendMenuSeparator();}
else {
idx++;
if (_isFunc(flags)) {flags = flags();}
if (_isFunc(entryText)) {entryText = entryText();}
menuMap.get(menuName).AppendMenuItem(flags, idx, entryText);
entryMap.set(entryText, idx);
idxMap.set(idx, func);
this.checkMenu = (menuName, entryTextA, entryTextB, idxFunc) => {
checkMenuMap.set(menuName, () => {
if (_isFunc(entryTextA)) {entryTextA = entryTextA();}
if (_isFunc(entryTextB)) {entryTextB = entryTextB();}
return menuMap.get(menuName).CheckMenuRadioItem(this.getIdx(entryTextA), this.getIdx(entryTextB), this.getIdx(entryTextA) + idxFunc());
this.btn_up = (x, y, object) => {
// Init menus
menuArr.forEach( (menuName) => {
this.createMenu(menuName);
// Add entries
entryArr.forEach( (entry) => {
if (!entry.bIsMenu) { // To main menu
this.addToMenu({entryText: entry.entryText, func: entry.func, menuName: entry.menuName, flags: entry.flags});
} else { // And append sub-menus
const subMenuName = _isFunc(entry.menuName) ? entry.menuName() : entry.menuName;
if (subMenuName != menuArr[0]) {
this.getMenu(subMenuName).AppendTo(this.getMenu(menuArr[0]), MF_STRING, subMenuName)
// Init checks
checkMenuArr.forEach( (check) => {
this.checkMenu(check.menuName, check.entryTextA, check.entryTextB, check.idxFun);
this.getCheckMenu().forEach( (func) => {
func();
// Call other object's menu creation
if (object && object.hasOwnProperty('btn_up')) {
object.btn_up(this.getNumEntries()); // The current num of entries may be used to create another menu
// Find currently selected item
const currIdx = this.getMenu(menuArr[0]).TrackPopupMenu(x, y);
let bDone;
this.getEntry().forEach( (func, entryIdx) => {
if (entryIdx == currIdx) {
func();
return bDone = true;
// Call other object's menu selection
if (!bDone && object && object.hasOwnProperty('btn_up_done')) {
object.btn_up_done(currIdx);
// Clear all
this.clear();
return bSupressDefaultMenu;
this.clear = () => {
menuMap.clear();
entryMap.clear();
idxMap.clear();
checkMenuMap.clear();
idx = 0;
// Helper
function _isFunc(obj) {
return !!(obj && obj.constructor && obj.call && obj.apply);
I have written some examples of use, and just 11 lines of code
Translate into this:
![X](https://hydrogenaud.io/index.php?PHPSESSID=qa5l082e4p61cn8ukti3sgobgm&action=dlattach;attach=19242;image)
No need to say that maintaining a few lines where you can easily see what each entry of the menu does is easier than having the code scattered at multiple places. Also changing entries order is just a matter of moving/adding/removing lines, since idx are calculated on the fly. The script requires no additional helpers and is ready 'as is' to be included on any other script. If you want a right button menu and a left button menu, then you simply create two different _menu() objects, with their entries, and use them on the different associated callbacks
Now back to the playlist creation topic, this helper can be used to create arbitrary menus linked to other scripts (like playlist creation functions). Similar to the image at bottom at the previous reply.
include(fb.ProfilePath + 'scripts\\SMP\\xxx-scripts\\top_tracks_from_date.js');
var year = new Date().getFullYear();
menu.newEntry({entryText: 'Top Tracks from ' + year, func: () => {do_top_tracks_from_date({playlistLength: 50, year: year})}});
year--;
year--;
Translates into:
![X](https://hydrogenaud.io/index.php?PHPSESSID=qa5l082e4p61cn8ukti3sgobgm&action=dlattach;attach=19246;image)
Full code is at top. Is wip, and at some point I will share it too on github along all scripts.
