Topic: Accuraterip: Pressing offset (Read 1274 times) previous topic - next topic
Re: Accuraterip: Pressing offset
https://wiki.hydrogenaud.io/index.php?title=AccurateRip#Pressings
Pressings, for AccurateRip's purposes, are where a batch of identical audio CDs is created by the pressing plant, then another batch is created, usually at a later date, with the same data but a different offset. The offset is due to variations in the way the master discs are replicated for the pressing machinery. Apart from this offset, discs across pressings are identical; the audio data on them is exactly the same.
There is a different pressing in the database and the offset in samples.
The full line is telling you your rip matches a different pressing when the given offset is mathematically applied.
korth
