Topic: EAC - FLAC command line options inconsistency between pages. (Read 462 times) previous topic - next topic
Hello!
I came up with this topic to ask about the information placed on this page:
http://wiki.hydrogenaud.io/index.php?title=EAC_and_FLAC
In which you can read:
(...) the output filename is unnecessarily included (-o %dest%), and output verification is unnecessarily enabled (-V): (...)
Then on this page:
http://wiki.hydrogenaud.io/index.php?title=EAC_Lossless_Backup
You can actually read the following:
Note: The green portion is where you would change the compression level or add settings for the FLAC encoder. You may want to add -V in order to verify that there were no encoding errors.
Okay, so in first page, we have the counsel to not use -V in newer versions of EAC (but that you should use it with old versions). May I ask why was this ever relevant or became irrelevant?
And then, on the second page, we have the saying that I may, if I want, use anyway the -V option in FLAC command.
Can anyone help me with this understanding and which setting should I actually be using?
I am already having quite a hard time ripping secure with a iHAS Lite-On drive, which caches audio and some CDs takes up from 15 to 30 minutes to rip. (I used to have a Sony Optiarc AD-7240 S which ripped much faster in secure mode, although with a little higher offset and supposed to not be ever caching audio). Should this -V be really added just for the sake of bit checking?
Thanks a lot.
Re: EAC - FLAC command line options inconsistency between pages.
Thanks Korth. I think the Wiki needs this reference! It all made sense when it carried on saying the problems -V can lead someone into.
