Topic: Semicolon in multivalue fields (Read 403 times) previous topic - next topic
The semicolon of multivalue fields in filenames is modified to comma with "File operations - Rename to...". I know that ; (semicolon) is not recommended for file names, but comma also. Is it possible to retain semicolon in filename, because of the possible later use with "Properties - Automatically fill values..."
Re: Semicolon in multivalue fields
Semicolon is not a bad character, so I think there is more to it than just renaming. If you go into Properties and try to format field <FOO> from field <BAR> that has a visible semicolon, it becomes replaced with a comma there. (I haven't checked thoroughly if that goes for literal semicolons too.)
I'm not very familiar with foobar2000 renaming operation, but I think you should use the $meta_sep() function in the new name pattern. For example:
$meta_sep(multivalue_field,";")
I'm late
Thank you, works with:
$meta_sep(multivalue_field,';')
$meta_sep(multivalue_field,;)
