Topic: Bug with using the shortcut ctrl+shift+v in the properties panel (Read 1142 times) previous topic - next topic
To reproduce.
1. Select an album, open the props panel, ctrl a, ctrl+c to copy the tags.
2. Select the same album in lossless format for example, open properties, ctrl a to select all the tags, delete and use the keyboard shortcut ctrl+shift+v.
3. It doesn't paste the tags.
Only when you use the context menu it works to paste the tags.
I've checked that my keyboard shortcut is not conflicting with anything else for pasting and it's not.
