Topic: "Split by (one separator per line)" field limitation (Read 838 times) previous topic - next topic
Currently, only 10 values can be entered in the only input field of the "Split Values" window. This is not enough, because the audio file tag fields are filled with not only English-language values, and the following words can be used as enumeration separators:
  • dhe
  • eta
  • ja
  • kaj
  • ndipo
  • og
  • ug
  • è
  • και
  • и
  • և
  • و
  • এবং
  • და
  • እና
Please remove the limit on the number of values, or raise it to at least 20.
