Re: How can I play only unplayed songs?
Reply #5 –
I found this option, which was not checked.
Automatically synchonize file tags with statistics (cause file tag rewrites during playback, disrecommended)
For this to register play counts, does this need to be checked? If I check it, should I really be worried about performance?
If not, then how does foobar2000 know which items had been played? Is it in a database of some sort?
My understanding is that the component updates the file tag sometime other than when the file is playing. So no, you wouldn't be helped by selecting this option in any normal situations, and no, there isn't a database. As long as the component updates the tag after the song is played, the song will then not be selected by a properly formed 'playcount=0' query.
For me the question is whether to give the time before updating a file a zero value, so I would hear only songs I've never listen to any of. Perhaps a value of one or two seconds or more would be better in this regard? Is there a variable value indicating the max time a song has been played?
