Topic: A tool to check for silent beginnings and endings? (Read 666 times) previous topic - next topic
Is there a tool that I can easily run in batch over many tracks at once that can check whether tracks start and end with digital silence or not, and just what the levels are if not?
Would be great to have as a foobar2000 component, but I'll take anything that can do this on many tracks at once.
Re: A tool to check for silent beginnings and endings?
I don't know, but Audacity has some macro features and stuff that might let you do something like that, so that's what I would look at.
mpTrim can trim off leading/trailing silence:
https://www.mptrim.com/
The paid version can do so in batch mode.
Thanks for the suggestions so far.
@Apesbrain I don't want to trim, I just want to verify, and it's going to be on lossless/flac files anyway.
@Brand I don't know... it takes a lot of time and RAM to open a whole album in audacity, and then, after running whatever macro I come up with, I'll have to browse manually to see what it's found, and all that I can think of with that would be the "find silence" function, which has a minimum of 100ms I think, and the results are displayed as label tracks. It would be less cumbersome to do as I do now, loading a single track with a spectrogram with a 60dB gain so that digital silence is visibly evident. But that's exactly the kind of visual checking that I want to avoid. I would like something that just scanned the starts and ends of track and said whether they start and end with digital silence or not (even if it's a very small, less than 100ms, chunk) or not, and, additionally, if there's a "silent enough" and/or "just background noise"  start and end.
@smok3 I guess that could work... if I knew enough scripting to make it, which I don't. In any case, I'm not scanning image files to find inter-track silences, like in the example you link, but scanning individual track files' beginnings and endings only. I don't care if there's silence in the middle or whatever. Would you say that should be achievable with SoX or FFMPEG and some scripting?
Sox
I'am looking at my own script from 2004 (and since I'd have to reread sox docs to understand it, I'am hesitant to post it), I think this might be helpful
https://digitalcardboard.com/blog/2009/08/25/the-sox-of-silence/comment-page-2/
Especially the
sox in.wav temp.wav silence 1 0.1 1% reverse
sox temp.wav out.wav silence 1 0.1 1% reverse
part looks familiar (again read the sox docs to understand whats up).
edit: Actually that will cut out 'silence', so I'am guessing not exactly what you are looking for.
Ffmpeg
This looks like a promising start (bash syntax)
 # get duration in seconds
ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 "$file"
171.964082
# silence detect in seconds
ffmpeg -i "$file" -af silencedetect=n=-50dB:d=0.01 -f null 2>&1 - | grep silencedetect
[silencedetect @ 0x7fffee38f440] silence_start: 0
[silencedetect @ 0x7fffee38f440] silence_end: 0.414762 | silence_duration: 0.414762
[silencedetect @ 0x7fffee38f440] silence_start: 166.15
[silencedetect @ 0x7fffee38f440] silence_end: 166.162 | silence_duration: 0.0110884
[silencedetect @ 0x7fffee38f440] silence_start: 166.3
[silencedetect @ 0x7fffee38f440] silence_end: 166.321 | silence_duration: 0.0218367
[silencedetect @ 0x7fffee38f440] silence_start: 166.33
[silencedetect @ 0x7fffee38f440] silence_end: 166.356 | silence_duration: 0.0256463
[silencedetect @ 0x7fffee38f440] silence_start: 166.367
[silencedetect @ 0x7fffee38f440] silence_end: 166.38 | silence_duration: 0.0130612
[silencedetect @ 0x7fffee38f440] silence_start: 166.395
[silencedetect @ 0x7fffee38f440] silence_end: 166.414 | silence_duration: 0.0188209
[silencedetect @ 0x7fffee38f440] silence_start: 166.425
[silencedetect @ 0x7fffee38f440] silence_end: 166.438 | silence_duration: 0.0131293
[silencedetect @ 0x7fffee38f440] silence_start: 166.438
[silencedetect @ 0x7fffee38f440] silence_end: 166.459 | silence_duration: 0.0207256
[silencedetect @ 0x7fffee38f440] silence_start: 166.461
[silencedetect @ 0x7fffee38f440] silence_end: 166.533 | silence_duration: 0.071542
[silencedetect @ 0x7fffee38f440] silence_start: 166.533
[silencedetect @ 0x7fffee38f440] silence_end: 166.57 | silence_duration: 0.0369841
[silencedetect @ 0x7fffee38f440] silence_start: 166.57
[silencedetect @ 0x7fffee38f440] silence_end: 166.593 | silence_duration: 0.0226984
[silencedetect @ 0x7fffee38f440] silence_start: 166.593
[silencedetect @ 0x7fffee38f440] silence_end: 166.615 | silence_duration: 0.0218367
[silencedetect @ 0x7fffee38f440] silence_start: 166.615
[silencedetect @ 0x7fffee38f440] silence_end: 171.913 | silence_duration: 5.29803
There is -to position and -sseof position which could be used to limit the amount of file to be scanned.
http://ffmpeg.org/ffmpeg.html#Main-options
An attempt at script
Usage example:
detectsilence *.m4a
may return
Jennifer Lopez - Jenny from the Block (Official Music Video)-dly6p4Fu5TE.m4a
no silence at start
no silence at the end
Jimmy Eat World - The Middle (Official Music Video)-oKsxPW6i3pM.m4a
no silence at start
[silencedetect @ 0x7fffcaeec7c0] silence_start: 4.02608
[silencedetect @ 0x7fffcaeec7c0] silence_end: 4.99921 | silence_duration: 0.973129
J-Kwon - Tipsy (Video)-VwXeN2FsE7w.m4a
[silencedetect @ 0x7fffd0f6c180] silence_start: 0
[silencedetect @ 0x7fffd0f6c180] silence_end: 1.2537 | silence_duration: 1.2537
John Mayer - Your Body Is A Wonderland (Official Music Video)-N5EnGwXV_Pg.m4a
no silence at start
JoJo - Leave (Get Out) Official Music Video [2004]-ggWyUEuGcWY.m4a
no silence at start
