Topic: Same album ripped with two different drives are not the same [split topic] (Read 1291 times) previous topic - next topic - Topic derived from Question about Pre-ga...
Not exactly...I would like to know if it is normal that the same album ripped with two different drives does not have the same bits compared with foobar bit-compare tracks plugin...
"Always account for the change."
Re: Same album ripped with two different drives are not the same [split topic]
If you're ripping the same CD on two different drives that require different read offset correction values then there may be a difference at the beginning of the first track and/or the end of the last track. (foo_bitcompare or EAC Compare WAVs)
korth
Korth thanks to moved my post in a new thread.  ;) This is the log from foobar:
Spoiler (click to show/hide)
But I have another album ripped with different drives/offset and says: All tracks decoded fine, no differences found.
It's hard to be certain from one reference track but the above log looks like 2 different CD's of the same album, probably made in different plants but created from copies of the same master recording. The engineers selected slightly different track start positions so each CD has a unique TOC layout with some/all tracks on one CD being slightly longer or shorter than on the other. One CD also has a different start position (data offset) than the other, this is normal for CDs made from different pressings. After allowances are made for all the differences, the data within is the same (which is what the log says happened).
If you compare the following two layouts, you'll notice the even though all track times are equal in minutes:seconds the length in sectors are different for each track.
https://musicbrainz.org/cdtoc/Sxbqarypucx1WaneLvYjBi0p.FQ-
https://musicbrainz.org/cdtoc/.M7wfe7w08.F8Ef09G9ER.cAvxI-
korth
Thanks a lot Korth! Excellent and clear explanation as always! :) For a moment I was in panic thinking that my rips was badly. eheheheh
I probably should have used these as the examples though.
https://musicbrainz.org/cdtoc/eFlVqEA19ZNcBU1n0W75d2EnLIo-
Track 1 is 20032 sectors (20032 x 588 = 11778816 samples) which matches the 1st file in your log.
https://musicbrainz.org/cdtoc/jOk5Rh.m3yPWwuv07mTe0EMpYFE-
Track 1 is 20033 sectors (20033 x 588 = 11779404 samples) which matches the 2nd file in your log.
just compare the center (length) column.
korth
