Topic: Great killer sample, easy to ABX on most codecs (Read 1753 times) previous topic - next topic
Good evening.
Long time lurker and first time poster in here.
I found THIS great sample by Jari Aalto.
He said he had some problems with LAME's V0 setting so I decided to test it myself including the other encoders, too.
MP3 is the most popular lossy codec in the world so let's test it first.
Using latest LAME 3.100.1 from RareWares.
lame -V0 input.wav
Spoiler (click to show/hide)
Very easy to ABX. I also tried --vbr-old switch and results were much better.
The second most popular lossy codec in the world, AAC-LC.
Using qaac 2.71 with CoreAudioToolbox 7.10.9.0.
qaac64 -V127 input.wav
I went with the highest quality setting -V127 but the problem is still there.
Drum hit at the beginning sounds different. Easy to ABX.
Opus, the most promising codec at the moment.
Using opus-tools-0.2-opus-1.3.1.zip from https://opus-codec.org/.
opusenc --bitrate 128 input.wav
English is not my primary language so I really don't know how to explain the difference that I can hear.
It is right around half a second. I also included the file encoded at 64 kbit/s that is very easy to ABX
and once you hear the difference you will know what exactly you need to listen to.
As you can see, I also had to change my sound card. My USB sound card just skips first ~two seconds on Opus
so I had to use PCIe card.
Everybody is focused on exhale now so let's test it.
Using latest exhale 1.0.8 from RareWares.
exhale 9 input.wav
Lower bitrates were not really good so I tried with higher bitrates. Still terrible. Deaf person can ABX this.
Not many people have xHE-AAC decoder so I also included the decoded file.
Everything above 16/44 is scam.
Always download first release, never remastered/HD release.
Re: Great killer sample, easy to ABX on most codecs
I cannot edit the original post so I apologize for double posting.
I just noticed this: DSD : WASAPI (event) : Izlaz (ASUS Xonar DGX Audio Device), 24-bit
I don't have any DSD device so I have probably chosen this by mistake.
Anyway, I didn't want that to affect the results so I redid the test using normal WASAPI.
Still not transparent.
Opus:
exhale:
This may not be of much help but from the Mega download the V0 version created with lame 3.100 has this really obvious additional noise on the beats in the beginning.
Even at V3 with an old 3.98 version this is way better.
AAC & LAME V0 --vbr new both have horrid pre echo clicks enough i don't need ABX to tell. Yet Opus & Vorbis are transparent at 160kbps. Never seen AAC perform so badly here.
Try alternative Noise shaping mode;
-V0  --vbr-new -f
wavpack hybrid 256k -hx4
-V0  --vbr-new -f
Or try --allshort V 0 --vbr-new, Had way more gains with samples in the OP.
Got locked out on a password i didn't remember. :/
