Re: How to convert WavPack Files to FLAC
Reply #27 –
About the flac compression. I believe your harddisk speed will be the bottleneck. So you might wanna use V5 instead of V0. Even for a test run.
Interesting! Note, this is for encoding&writing time during a test.
For the permanent set, use -8 and leave it overnight. Encoding is done once, and -8 has same decoding CPU load but saves space.
