Topic: clicks on sub-windows do not always register (Read 88 times) previous topic - next topic
Hi there,
I hope this is not a duplicate, but my google-fu and search of this forum didn't yield any results.
For years now, over several versions of Foobar and I think since Windows 8 my clicks don't always register on new sub-windows like the preferences screen or the process indicator. I then have to click an entry in the AlbumList or the playlist, and then can move the window or click something in it. Sometimes I can move it but not click, so rinse and repeat until finally it works. Does anybody else have this problem?
I also have a duplicate entry of the DSP entry under View, with Equalizer being the only entry, crashing the program. Maybe it's related.
A fresh install of v1.6.1 does not seem to suffer these problems, at least after short use. I have spotted some rather old plugins and have to check if I actually use them, anything deprecated in there?
Core (2020-09-02 09:59:06 UTC)
    foobar2000 core 1.6
foo_abx.dll (2019-03-11 19:32:20 UTC)
    ABX Comparator 2.0.6d
foo_ac3.dll (2019-02-21 02:09:33 UTC)
    AC3 decoder 0.9.13
foo_albumlist.dll (2020-09-02 09:58:12 UTC)
    Album List 4.7
foo_audioscrobbler.dll (2010-09-14 11:37:34 UTC)
    Audioscrobbler 1.4.7
foo_bitcompare.dll (2019-09-16 16:07:57 UTC)
    Binary Comparator 2.1.5
foo_burninate.dll (2011-03-16 10:31:54 UTC)
    Audio CD Writer 3.0.3
foo_cdda.dll (2020-09-02 09:58:14 UTC)
    CD Audio Decoder 1.6
foo_comserver2.dll (2006-07-31 19:13:20 UTC)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2020-09-02 09:58:18 UTC)
    Converter 1.6
foo_convolve.dll (2019-12-18 20:47:44 UTC)
    Impulse Response Convolver 0.3.3
foo_dbsearch.dll (2007-01-25 19:58:48 UTC)
    Database Search 1.4
foo_discogs.dll (2020-04-11 05:21:32 UTC)
    Discogs Tagger 2.23
foo_dsp_eq.dll (2020-09-02 09:58:06 UTC)
    Equalizer 1.2.2
foo_dsp_resampler.dll (2010-02-07 17:21:17 UTC)
    SoX Resampler 0.5.4.1
foo_dsp_soundtouch.dll (2012-12-22 15:40:56 UTC)
    SoundTouch DSP 1.1
foo_dsp_std.dll (2020-09-02 09:58:04 UTC)
    Standard DSP Array 1.6
foo_facets.dll (2011-11-20 17:10:39 UTC)
    Facets 1.0
foo_fileops.dll (2020-09-02 09:58:12 UTC)
    File Operations 1.6
foo_freedb2.dll (2020-09-02 09:58:12 UTC)
    Online Tagger 0.8
foo_input_monkey.dll (2019-12-18 20:47:44 UTC)
    Monkey's Audio Decoder 2.3.1
foo_input_shorten.dll (2017-04-12 10:56:03 UTC)
    Shorten decoder 0.4.2.3
foo_input_std.dll (2020-09-02 09:58:38 UTC)
    FFmpeg Decoders 3.4.6-0ac9001
    Standard Input Array 1.6
foo_input_tak.dll (2020-03-21 18:06:42 UTC)
    TAK Decoder 0.5.1
foo_masstag.dll (2019-09-16 16:07:58 UTC)
    Masstagger 1.8.5
foo_midi.dll (2020-10-06 18:00:12 UTC)
    MIDI Player 2.4.0
foo_out_asio.dll (2012-11-17 10:57:22 UTC)
    ASIO support 2.1.2
foo_out_wasapi.dll (2018-07-16 20:50:00 UTC)
    WASAPI output support 3.3
foo_pqview.dll (2008-03-11 18:02:54 UTC)
    Playback Queue Viewer 0.2
foo_queuecontents.dll (2012-11-17 10:57:23 UTC)
    Queue Contents Editor 0.5.1
foo_record.dll (2019-04-11 14:32:20 UTC)
    Recorder 0.2.1
foo_rg_trn.dll (2010-01-13 23:01:01 UTC)
    ReplayGain override 0.1.3
foo_rgscan.dll (2020-09-02 09:58:16 UTC)
    ReplayGain Scanner 1.6
foo_ui_columns.dll (2020-09-03 19:55:18 UTC)
    Columns UI 1.6.0
foo_ui_std.dll (2020-09-02 09:58:32 UTC)
    Default User Interface 1.6
foo_uie_albumlist.dll (2020-09-26 19:29:20 UTC)
    Album list panel 0.4.1
foo_uie_console.dll (2020-04-11 09:10:10 UTC)
    Console panel 1.0.1
foo_uie_trackinfo_mod.dll (2007-01-05 13:36:20 UTC)
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_vis_peakmeter_spectrum.dll (2008-02-23 13:12:06 UTC)
    Peakmeter Spectrum Visualisation 0.1.0.2 beta
foo_unpack.dll (2020-09-02 09:58:18 UTC)
    ZIP/GZIP/RAR/7-Zip Reader 1.9
foo_utils.dll (2008-02-08 22:26:58 UTC)
    Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2020-07-02 09:34:34 UTC)
    File Integrity Verifier 1.4
foo_vis_shpeck.dll (2011-07-20 22:31:42 UTC)
    Shpeck - Winamp vis plugins wrapper 0.3.7
foo_vst.dll (2013-01-02 13:49:17 UTC)
    VST 2.4 adapter 0.9.0.3
foo_wave_minibar_mod.dll (2020-09-23 19:40:28 UTC)
    Waveform Minibar (mod) 1.0.38
foo_whatsnew.dll (2017-04-12 10:56:02 UTC)
    Feature Watcher 1.1.1
I kinda established my layout and colour scheme and all the little tweaks a long time ago (when I was maybe 15?), when the first big wave of plugins hit and columns_ui became a well known thing, only updated or replaced deprecated plugins and at one point reconfigured for widescreen, and now with 32 I realized that I kinda forgot all the config specifics again and now feel very old. point is ... I don't like the idea of trying to migrate my settings to a new install to find out which plugin could be the problem. call me lazy. but I also have more stuff to do then when I was a student :D so really I'm trying to be productive. but with help.
 thank you
