Topic: v1.6.2 Beta 6 - Windows + Shift + Right Arrow triggers Play/Pause (Read 471 times) previous topic - next topic
For a clean install of foobar2000 if you use press Windows + Shift + Right Arrow to move foobar2000 window to next screen, it also triggers Play/Pause.
Re: v1.6.2 Beta 6 - Windows + Shift + Right Arrow triggers Play/Pause
I've tested this on my work computer and i can't reproduce it. i have no interrupts when i use the keyboard shortcut to bounce between screens.
Tested with 1.6.1 and 1.6.2b6
It seems to occur only for Windows + Left Shift + Right Arrow.
it doesn't happen when Windows + Right Shift + Right Arrow is pressed.
Also, it seems to happen regardless of the window that is currently active...
It evens happen when you press Windows + Right Shift + Right Arrow when screen is locked.
OS: Windows 10 2004
Still can't reproduce it on my machine.
Sounds like there could be some other software on your machine that's messing with your global shortcuts\hotkeys.
Maybe open up task manager and kill a process and test the shortcut again, rinse and repeat until you find what is messing with Foobar2000.
Some laptops or keyboards use such hotkey arrangements to replace actual dedicated media keys.
