Topic: When downloading mp4 (AAC) files, the player crashes (Read 745 times) previous topic - next topic
once again completely reinstall the player, the problem occurs when processing mp4 files, this is not a coincidence, 2 weeks ago I had to completely reinstall the subject
Spoiler (click to show/hide)
Re: When downloading mp4 (AAC) files, the player crashes
Maybe try with a clean portable install and see if you can make it crash. if you can't then it's one of your many plugins that could be causing the problem.
It looks like foo_jscript is the cause.
I'm sorry, I'm just French and I don't know much English, I use Google translator. Indeed, removing the Java script component allowed you to launch the player, scrolled through the log, did not even understand how you determined it, thank you. I have several scripts running on this component and don't want to work on spider monkey
Since I maintain the component, I *might* be able to fix it but only if you can understand any of the following...
Can you answer the question about using the editor dialog from the other thread?
Can you attach the crash dump (.dmp) files.
What scripts do you use?
Does it only happen when playing certain tracks? If using scripts that fetch online info based on track metadata, it might the content of the response that isn't handled properly.
zippyshare is blocked in my country (UK). Just use the forum file upload when replying.
@snotlicker
I've attached Mrakobes dump for you.
Thanks for that but it seems I'm too incompetent to make use of it!  :))
I have ideas from the crash log text but I can't pursue them with someone I can't communicate with.
The dump file is compressed with 7zip or is there something wrong with the dump file?
Sorry, i did compress the dump file with 7zip since i didn't want to waste space on the HA servers.
I'm sure 7-zip compression is not a problem. Debugging a minidump requires you to have kept the debug symbols of the build used in the crash, @snotlicker. Load your project, you can drop the minidump in the same directory where the binary and debug symbols are and you won't need to configure anything, load the .dmp to visual studio and hit Debug with Native Only. You'll get stack trace and the debugger shows which function triggered the problem.
Without the symbols it won't work so well:
I didn't save the pdb so that's my fault. I tried checking out the last release from my git history and rebuilding but that didn't work. I'll make sure to keep future copies.
I have some ideas which I could pursue with someone I could converse with but I'm English and only speak English. They're apparently French with very selective English skills
https://hydrogenaud.io/index.php?topic=118660.msg978840#msg978840
and Russian
https://foobar2000.ru/forum/viewtopic.php?p=78087#p78087
Easiest fix:
Thank you for your help and participation in the problem, I completely switched to the spider monkey panel and everything seems to work
