Topic: EAC ver 1.5 - Weird error - Unhandled exception Compression error (Read 238 times) previous topic - next topic
For one of my CD's (Franz Liszt: A Faust Symphony (in Three Character Portraits after Goethe), S. 108- I. Faust) shows Unhandled exception error (compression error) on of the tracks.
The third track shows the error, the first two tracks rip fine. What could be the issue?
https://www.amazon.com/Liszt-Faust-Symphony-Pr%C3%A9ludes-Prometheus/dp/B00004TTIM/ref=pd_sbs_15_1/131-7546784-9347637?_encoding=UTF8&pd_rd_i=B00004TTIM&pd_rd_r=285be3eb-8f0f-4f16-9a68-ef39af22ce52&pd_rd_w=Lf9GH&pd_rd_wg=5cMwO&pf_rd_p=b65ee94e-1282-43fc-a8b1-8bf931f6dfab&pf_rd_r=8XS77FCWKADECYYW4ZEY&psc=1&refRID=8XS77FCWKADECYYW4ZEY
Re: EAC ver 1.5 - Weird error - Unhandled exception Compression error
Can you rip the track in wav, zip it and put it somewhere? PM the link.
Also, to which compression format are you compressing?
Could it be that the filename is too long, so the compressor is exiting with the error rather than telling you what is the problem?
Ticking the "Check for external programs return code" box on the External Compression tab might provide more info about the error.
Capture and post the window with the error message.
The extraction log could be helpful as well.
korth
You were right. The Filename was too long. I shortened it in EAC and it worked fine. Thanks.
This would have been my next step but shortening the file name worked. I am learning slowly. The challenges of being a senior citizen.
