OPUS vs WMA - Which one sounds better ? 2020-09-25 13:25:48 I need a clear information which one sounds better?? OPUS or WMA ??I have a lot of songs in FLAC. I need to convert those files.
Re: OPUS vs WMA - Which one sounds better ? Reply #1 – 2020-09-25 14:06:26 You should perform your own listening test.https://hydrogenaud.io/index.php?board=40.0Hydrogenaudio Terms of Service Last Edit: 2020-09-25 14:36:11 by korth
Re: OPUS vs WMA - Which one sounds better ? Reply #2 – 2020-09-26 16:42:25 WMA is a more than 20 year old format that hasn't been developed in over 15 years. It's not likely to be the best at anything.
Re: OPUS vs WMA - Which one sounds better ? Reply #3 – 2020-09-26 18:15:31 I mean, is WMA even better than "state of the art" mp3 at this point (which really hasn't advanced much if at all in the last 10+ years either)
Re: OPUS vs WMA - Which one sounds better ? Reply #4 – 2020-09-27 10:32:16 Indeed, the best thing you could do is your own listening test at a given bitrate. As Opus is an open codec and developed actively and WMA is proprietary and not developed anymore, my advice is to not even consider WMA. But I am of course not familiar with you own considerations/use cases.
Re: OPUS vs WMA - Which one sounds better ? Reply #5 – 2020-09-27 13:28:26 Opus is the best at low bitrates. At mid-high bitrates they should perform similarly. Opus is quite a standard today and widely compatible. WMA is pretty much dead and being phased out.
Re: OPUS vs WMA - Which one sounds better ? Reply #6 – 2020-09-28 20:15:20 AAC-LC is a better choice.https://hydrogenaud.io/index.php?topic=102875.msg988476#msg988476And Opus is even superior.https://listening-test.coresv.net/results.htmIf your device only supports MP3/WMA, WMA is worth consideration.If your device supports AAC, AAC is the preferred option.It's your choice.
Re: OPUS vs WMA - Which one sounds better ? Reply #7 – 2020-09-29 09:18:42 Why would an end-user encode to WMA by now? Must be if they have some hardware (an in-car unit?) that doesn't support anything else?
Re: OPUS vs WMA - Which one sounds better ? Reply #8 – 2020-09-29 20:15:48 Even then I suspect you're probably better off with mp3
