Topic: How to output to 2 different headphones with different EQ presets ? (Read 944 times) previous topic - next topic
Re: How to output to 2 different headphones with different EQ presets ?
Entirely bypassed ? I wasn't expecting it, that's a real shame :(
Would it be so hard to modify DSP Manager behaviour, so that when it wants to pass a multichannel audio to a DSP component that only handles stereo audio, at least channels 1&2 are passed instead of completely bypassing the component ?
@Peter or another core dev, if you're listening...
You need 3 Foobars.
First F2K send audio to 2 others F2K:
Foobar2000 (first instance) - set output buffer to max. Set output to null output.
Start UPNP server. Send output format = PCM or Wave.
Output - Stereo
Start playing your music or set foo scheduler for to start playing.
Foobar2000 (second and third instances) :
Set output - DAC 1 for F2K (second) and DAC 2 for F2k (third).
Set output stereo or multichannel, whatever you choose (dsp manager options)
Load to dsp manager preset 1 of your VST plugin  - to F2K (second)
Load to dsp manager preset 2 of your VST plugin - to F2K (third)
Set foo scheduler for both to start playing at same time.
Because there is delay in streaming - set foo scheduler to delay time - 7 seconds, is the time for buffering stream for both players when F2K (first instance) start to playing.
With these settings you can't here any delay in sound between both Foobars that receive stream via UPNP protocol.
You need: https://www.foobar2000.org/components/view/foo_upnp and some internet, cable or wireless.
