Topic: How to output to 2 different headphones with different EQ presets ? (Read 642 times) previous topic - next topic
Hi everyone,
I forgot to say "simultaneously"  :D Here's the story :
My GF and I have two pairs of headphones (which we're gonna upgrade soon). We like to listen to them simultaneously and compare our impressions on music.
I'd like to EQ both headphones to get the most out of them, using sites like this one : https://www.reddit.com/r/oratory1990/wiki/index/list_of_presets
But of course if I add an EQ to foobar's DSP, that EQ will apply to both headphones, so it will only be ideal for one of them.
So what I'd like somehow would be foobar to output simultaneously on two different outputs (two USB ports I guess), each output having its own EQ preset. Something like this :
FOO --> EQ1 --> USB1 --> DAC1 --> Amp1 --> Headphone1
BAR --> EQ2 --> USB2 --> DAC2 --> Amp2 --> Headphone2
Doesn't sound very easy or even possible. But is there a way ?  :-\
The only thing I've thought would be having two separate instances of foobar, outputting to different USB ports. But that would not be useful at all, because we'd need to perform each song search twice, hit play twice, we couldn't have shortcuts for both instances I guess, etc..
Another solution could be having some external software that would be able to duplicate foobar's output, EQ it individually and output it on both USB ports. Something like this :
foobar --> External software --> output1 --> EQ1 --> USB1
..........................................................--> output2 --> EQ2 --> USB2
Maybe there are other solutions. I don't know.
Thanks in advance for your help.
Re: How to output to 2 different headphones with different EQ presets ?
You could potentially sync the songs using something like foo_upnp. Then use foobar on different PCs with their own EQ settings/outputs.
Thanks Daeron. Although that would mean having two different PCs.
Here we're talking about listening in the same room, side by side, with only one PC.
Couldn't I sync the songs between two instances of foobar, on a sort of master/slave mode?
Then each instance would output to its own audio device, with its own EQ settings, and the problem would be solved!
Actually it's even more complicated. Instead of having two headphones I could have many (actually I have already more than two). But I would only play two at a time.
So I'd have n headphones, and n instances of foobar, each one with its own settings. And two DACs / headphone amps.
Among these instances, I would select any two at a time: instance A and instance B.
Instance A would output to DAC 1, and instance B would output to DAC 2.
This is what I'd like to achieve.
Just set up EQ in each of your DAC's control panel. If you're having problems duplicating output, there's software for that like Voicemeeter or AudioRouter. Voicemeeter got to have its own EQ too.
Thanks @Pollux88 .
You are assuming that my DACs have a built-in EQ, but it's not the case unfortunately.
Voicemeeter looks nice since its specs say "3 Inputs (2 physicals / 1 Virtual) and 3 Outputs (2 physicals / 1 Virtual)".
I would need 1 Input (Virtual) from foobar, and 2 Outputs (physical) to DACs.
Unfortunately, Voicemeeter's EQ is very basic (only 3 band).
I'm looking for a parametric EQ with about 10 bands, because that's what's needed for most of the headphone presets that I linked in my OP.
Voicemeeter Banana looks better, because it has a parametric EQ with 6 bands/cells. It's close to what I need : https://vb-audio.com/Voicemeeter/banana.htm
Any clues ? We're almost there ! :D
foobar2000+ASIO4ALL+2 virtual sound cards+2 instances of VSTHost
or, if you can afford Convolver instead of EQ, it will be much simpler:
foobar2000+Matrix Mixer+Convolver+ASIO4ALL
Matrix Mixer copies 2 channels, so signal becomes 4-channel. Then Convolver with 4-channel impulse (with different EQ preliminarily applied to different channels) process this signal. Then ASIO4ALL outputs different channels to different devices using custom channel mapping.
Hi Rollin, you're everywhere ! Saving the day again ! :D Thank you.
Actually I think the "simpler" solution would be Voicemeeter Banana, IF it had 10 bands. But it hasn't  :P  I have just emailed the developer, maybe he can add 4 more bands, who knows ?
Yes, I could use convolver instead of EQ, thanks to your excellent tutorial in that other topic. :) So that would mean :
  • Creating a 4-channel pulse for a given frequency (e.g. 44 KHz)
  • Loading it into Audacity
  • EQing channels 1 and 2 for a given headphone preset
  • EQing channels 3 and 4 for another headphone preset
  • Saving the EQed pulse
  • Feeding the convolver with it.
But Audacity's EQ doesn't seem to be a PEQ (with Frequency, Gain, Q-Factor, etc.). And the aforementioned presets require a PEQ. Take this one for example (see attached pic). So if I had a classic 10-band PEQ for Audacity, I guess I could solve my issue. Any clues ?
FYI, if I had more than 2 headphones, that really would complicate things, because i would need to create many pulses. Example :
3 headphones => 3 pulses (pulse12, pulse13, pulse23) for any given frequency
4 headphones => 6 pulses (pulse12, pulse13, pulse14, pulse23, pulse 24, pulse 34) for any given frequency
And that quickly escalates by n! factor (5 headphones = 10 pulses, 6 headphones = 24 pulses...).
Then I guess I would need to create as many instances of foobar as required (because that would be easier than switching pulses). For instance foobar12, foobar13, foobar23. And launch the right instance depending on the used headphones. Am I right, or is there a simpler solution ?
Audacity supports VST plugins. And Audacity is not the only audio editor. Also, what is problem to just draw EQ curve as seen on picture?
Somehow I knew you would say that, lol.
Another solution would be replacing the 2 DACs by a single multichannel DAC (ex : https://www.gearslutz.com/board/product-alerts-older-than-2-months/1294869-esi-launches-ugm192-gigaport-ex.html ). That would eliminate the need for ASIO4ALL. foobar would just output 4-channel sound every time : foobar2000+Matrix Mixer+Convolver, all to a single USB output.
You can equalize your headphones using Minidsp HA-DSP
DSP Headphone amplifier Equalizer.
Thanks. That could work for most headphones, but not for some electrostatic headphones like the Koss ESP/95X that come with their own amplifier. I'm looking for an universal solution, since the Koss is in my plans.
As for precise parametric eq, ffmpeg has parametric eq - https://ffmpeg.org/ffmpeg-filters.html#equalizer
For example, equalizing impulse for m50 will look like
ffmpeg.exe -i "impulse.wav" -af "lowshelf=f=90:g=2.8:t=q:w=0.9, equalizer=f=200:g=-3.3:t=q:w=0.9, equalizer=f=290:g=4.5:t=q:w=1.8, equalizer=f=2800:g=-3.7:t=q:w=1.5, equalizer=f=3670:g=2.7:t=q:w=4.5, equalizer=f=4340:g=-5:t=q:w=4.5, equalizer=f=5800:g=2.8:t=q:w=3.5, equalizer=f=7000:g=-3:t=q:w=6, equalizer=f=8100:g=-4.6:t=q:w=5, highshelf=f=11000:g=-10:t=q:w=0.8" -c:a pcm_f32le "result.wav"
You can output to 2 different headphones with different EQ presets using Jriver. 2 linked zones can be configured with separate parametric equalizer or convolution dsps.
Rollin, you always come with great solutions ! But sometimes they are a bit geeky for poor little me. I'm not a CLI expert like you.
Thanks @sacduser . Well, I'm an old foobar fan and I don't intend to change, lol.
I would use JRiver if I could still use foobar's GUI, and just play music on JRiver. In other words, JRiver would need to be pretty invisible to me, as I'd keep using foobar. Is that possible somehow ? Maybe with foo_run or another component ?
You can enable the WDM feature of Jriver and direct the output from Foobar to Jriver.
Thanks, I'll look into it.
Unrelated question : let's say I have 4-channel audio going out of foobar. Normally each listener will have volume control via the physical knobs on both headphone amps. But what if there weren't headphone amps ? Just wondering. Would foobar be able to provide separate stereo volume controls for channels 1-2 and channels 3-4 ?
I'm not talking about typing figures in Matrix Mixer, becuse that's unpractical. Rather about keyboard shortcuts. Two keys for Vol+/- on channels 1-2, and two other keys for Vol+/- on channels 3-4. Can this be achieved ?
OK, let's forget about the previous question if nobody can answer it.
I have tried @Rollin 's method (foobar2000+Matrix Mixer+Convolver) and indeed it works !
For that, I have found what seems to be a nice free VST PEQ for Audacity : https://www.kvraudio.com/product/qrange-by-lkjb
(if you have something better to suggest, please do)
So I created a 4-channel impulse with Audacity, then I applied the PEQ to it, and I saved the result (wav 32-bit float).
Then within foobar's DSP Manager, I used Matrix Mixer ("Convert stereo to 4 channels") and Convolver (loading the EQed impulse).
It works ! :D
I'm just not sure of the QRange PEQ settings that I've made (and I haven't found a user manual). Here's my test EQ, taken from here :
I'm wondering this (remember I'm a beginner on this stuff) :
  • What Process Mode must I choose? (click on the cogwheel to access them). "Low distortion", "Medium Distortion & OK Frequency Response" or "Good Frequency Response" ? I don't really understand the compromise that needs to be made between distortion and frequency response, sorry.
  • What are the Peak Curve (green) and the Hold Curve (red) ?
  • What means "Pre / Post" and "Routing : Mid" ?
If anybody can help... Thanks again !
https://lkjbdsp.wordpress.com/2020/05/21/qrange-distortion/
Yes, that explains a lot indeed. However, the author talks about using QRange in real time, for real music and with real time constraints. I'm only using QRange once for a single calculation, with a very simple pulse signal, to transform it and save the result. Then I'm done with QRange. So I don't know what setting would be best for my particular use.
Also, all headphone PEQ presets ask that we reduce the global gain, which is normal. But since we're talking about an impulse here, do I still need to reduce the global gain ? For example here's how the 44.1 KHz pulse looks after EQ, with a global gain of -5.5 dB. Do you see my point ?
Yes.
For the record I have just realized one thing: why would I need Matrix Mixer when foobar's DSP Manager gives me already the option "Convert stereo to 4 channels" which is exactly what I need? :D
Makes things even simpler.
I still don't know which one of the 3 Process Modes I should choose within QRange though.
