Topic: The pause doesn't stop soon enough. (Read 482 times) previous topic - next topic
Hi, I'm Japanese and I'm not good at English.
Sorry if you can't understand me. I'm playing on an audio interface (focusrite scarlett solo) asio setting, but when I press pause, it delays and pauses after about a second.
 I don't have this problem with DS playback.
Is there any way to fix this?
Re: The pause doesn't stop soon enough.
Do you by any chance have enable smooth seeking, pause and volume changes enabled? If so, you can either try disabling it, or adjusting the pause and stop fade in and fade out times.
I've set that setting to disabled.
It may be due to the setting of the component, asio2.
What size buffer have you set in the ASIO driver settings?
The buffer is set to 128.
Changing this setting does not improve the situation.
Any specific reason why you use a third party ASIO plug-in instead of the official one?
Resolved.
The problem seems to be in the buffer size. It seems that the software I'm using, "Rational Acoustics Smarrt", was controlling the buffer size of the audio interface on its own.
