Re: Musepack in 2020
Reply #26 –
It's not really transparent by default, I've found it needs at least 2 workarounds:
1) need to adjust ATH per track using option ltq_gain based on track loudness (not really viable to do by hand, because each track needs a different value, so you'd need to script that; I wrote it already btw, can upload if someone's interested), otherwise it will delete too much stuff from very quiet tracks
2) it's easily ABXable on a "killer" sample "Fighter_Beat_Loop" even at maximum quality preset (and this sample sounds quite similar to sounds which can be found in some music genres), and I've found only 1 way to work around that (add `--nmt 18` option) which also raises bitrate quite a lot, making it harder to say it's competitive with modern codecs)
magicgoose, as you username is highlighted on the Musepack forum lately as their latest user addition, I wonder if you came across this post by Frank Klemm from which I quote the following as, IMO, fits the bill perfectly regarding your own adjusting of Musepack's quality settings:
Simply, there's usually a very high chance that using --quality 6 for example would give you better quality at a similar average bitrate to the one you got with the manually "tweaked" --quality 5.
That at least makes sense to me as I've been a relatively happy bunny with --quality 6 for the times (non electronic music mainly) I'm not using Wavpack hybrid.
