Topic: new internal decoders name on latest beta 1.6.1 (Read 394 times) previous topic - next topic
On Decoding preferences, there are two new decoders, HLS Decoder and MPEG TS Decoder. I wonder if you would consider to rename them to "foobar2000 <decoder name>" just like other internal decoders/demuxers or you actually intended to have them named like that. thanks
Re: new internal decoders name on latest beta 1.6.1
Fixed for the next beta, thanks for pointing out.
@Peter , can you please clarify, what file extensions and what audio codecs MPEG TS decoder is supposed to support?
I had to write a very basic MPEG TS reader for .TS streams used by HLS radio. It only supports AAC payload.
Thanks. But it seems that his MPEG TS decoder also tries to decode local *.ts files. And if it fails in this case, it doesn't report any error message at all and it can't fallback to other decoders that supports *.ts (foo_input_ffmpeg, for example) if they are lower in decoders priority list.
Sample *.ts - https://www.dropbox.com/s/bway6x7jeej8khf/9876h96vr.ts?dl=1
