Topic: Columns UI - Set rgb with value from a variable (Read 244 times) previous topic - next topic
I'm struggling with getting this to work in the globals variables tab.
I want to have both a global for the value and the RGB.
$set_global(txthighlightvalue,216,237,201)
$set_global(txthighlightclr,$rgb($get_global(txthighlightvalue)))
Is this possible to assign the value then use it again in the rgb function?
Re: Columns UI - Set rgb with value from a variable
I haven't tested for myself (sorry, back to Default UI since 2014...), but setting the variable to
$set_global(cTxtHighlight,$rgb(216,237,201))
should work. Then set color anywhere with
$get_global(cTxtHighlight)
Source: https://brother-john.net/tagz/create-colour-scheme.html
If you really need to store the individual values for R, G, B, I fear you will have to use three globals:
$set_global(cTxtHighlightR,216)
$set_global(cTxtHighlightG,237)
$set_global(cTxtHighlightB,201)
and then use them like:
$set_global(cTxtHighlight,$rgb($get_global(cTxtHighlightR),$get_global(cTxtHighlightG),$get_global(cTxtHighlightB)))
Thanks for the reply.
Individual variables? Really, there's no other way to set the 3 values to one variable?
