Topic: foo_out_pulse - pulseaudio output (Read 3718 times) previous topic - next topic
Hello, I have made a component for Wine users, to interface directly with Pulseaudio. It's definitely 'beta', hopefully someone finds it useful. In the future I will try to enable streaming to other IPs, for example to allow streaming to a Raspberry Pi or similar. Please see the setup notes.
Home
Download
Re: foo_out_pulse - pulseaudio output
Works great.
Completely remove the pauses when wrting a lot of tags.
Works great here too. Wondering what's up with the winelib detection mode I saw in the source code. Also awaiting support for linking the foobar2000 volume control with the PulseAudio volume control, as currently, the player's own volume control is non-functional.
For the client library I'm using the only build of Pulseaudio available for Windows, which is pretty old (v1.1, current version is 13). I had a go at getting the latest version to build but haven't been able to yet.
I was considering ways to allow better intergration by avoiding the need to set up and use the TCP protocol - ie. communicate directly with Pulse's Unix socket like native applications do. There are two ways I can think of to do it. One is by modifying the Pulse library to directly make the syscalls for accessing the socket. The library is pretty complex so that's probably too difficult, especially as I can't even build Pulse yet.
The other is you can build a DLL using wine tooling that exports certain functions as a DLL and implements them using code compiled for Linux. You can therefore build a DLL that exports the same interface as the libpulse, and passes through every function call to the system's native libpulse.so, which then handles the socket connection etc. as usual. This is basically how Wine's own audio implementation works, except that it is more complex as is translates the Windows API to Pulse's. By passing through the libpulse API everything is much simpler, and there is basically no impedance mismatch between foobar's API and pulse's. The advantage of this is that it uses the most up to date client library on your system, which might have improvements at this point such as power use, and it avoids the need for the TCP protocol. The downside is that you're building a wine DLL that links against Wine and Pulse on your system, so I believe you will have to rebuild it for every update of those packages. Also, while it worked well for a while when I was testing it, at one point it started crashing and as you can imagine it's significantly harder to debug.
So overall I think it's not worth pursuing, the possible advantages are quite small anyway. If you are interested you can look at my libpulse-wine repo which builds the DLL, that you can drop in as a replacement to the bundled one.
I have made a new release, with the following changes
- Custom anti-popping seek/track change fading implementation that keeps PA fully buffered while allowing instant seeking etc. The fading is configurable in Advanced Preferences -> Playback -> Pulseaudio output
- Uses a new Pulseaudio v13 build, should fix sometimes high CPU use after seek or manual track change
- Two way PA volume control integration
- More responsive playback start/track change
- Fix bug playing very short files where playback would be delayed
- Fix hang on last item in playlist
I would be interested to see if anyone has problems with this release seeing as it has a Pulseaudio client library that I compiled myself. It seems OK for me so far. Also any problems with the fading implementation, as it assumes that the fading can be calculated at a certain speed. Maybe on certain setups the assumption will be incorrect.
If it crashes horribly, you can copy the 'pulse' folder from the previous release. The only issue with it is that after seek/track change, sometimes its CPU use will jump up until playback is stopped.
Download
v0.1-beta - works
v0.2-beta - playback is sped up, ~25x
v0.1-beta - works
Thank you for testing. Could you try the attached version please?
Could you also send me the output of the command pactl list?
I tested the 0.2 release on Github already, it works fine. No "speed up" issues.
Tested on fresh, clean, portable install, it worked then the problem returned. It scrolls through a two minute track in five seconds  :o . Must be some obscure hardware/software config issue on my side.
Apologies for wasting time.
I think I can see the problem causing the fast playback - I am not handling an error condition properly, instead of failing on error the playback will speed up. I'll add some better error reporting, maybe we can work out what's wrong. I would be interested in knowing your distribution/wine version/output of pactl list still if you have time. Maybe I can set up a similar test envronment.
Version 0.2 installed.
I test going back and forward in the songs a lot and not problem at all.
Also now the playback stops correctly at the end of playlist, stop after current and stop after queue.
And the most cool of all; the volume of foobar finally changes the pulseaudio volume.
Love that you're working on this. I'm having the same superfast playback issue, running Voidlinux, Wine 5.16, and pulseaudio 13.
Do you need the whole pactl list or just the running sink?
Sink #0
State: RUNNING
Description: Built-in Audio Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 7
Mute: no
Volume: front-left: 20316 /  31% / -30.52 dB,   front-right: 20316 /  31% / -30.52 dB
        balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
Latency: 1999385 usec, configured 2000000 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "32"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "CX20756 Analog"
alsa.id = "CX20756 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0xb3614000 irq 51"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card1"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "9c20"
device.product.name = "8 Series HD Audio Controller"
device.form_factor = "internal"
device.string = "front:1"
device.buffering.buffer_size = "768000"
device.buffering.fragment_size = "384000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Conexant CX20756"
alsa.components = "HDA:14f15114,1179f922,00100100"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-speaker: Speakers (priority: 10000, not available)
analog-output-headphones: Headphones (priority: 9900, available)
Active Port: analog-output-headphones
Formats:
pcm
Sink Input with your plugin playing at 25x speed:
Sink Input #0
Driver: protocol-native.c
Owner Module: 24
Client: 1
Sink: 0
Sample Specification: float32le 2ch 48000Hz
Format: pcm, format.sample_format = "\"float32le\""  format.rate = "48000"  format.channels = "2"  format.channel_map = "\"front-left,front-right\""
Corked: no
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
        balance 0.00
Buffer Latency: 0 usec
Sink Latency: 1999162 usec
Resample method: copy
Properties:
media.name = "Audio"
application.name = "foobar2000"
native-protocol.peer = "TCP/IP client from 127.0.0.1:47746"
native-protocol.version = "33"
application.id = "foobar2000"
application.icon_name = "foobar2000"
application.process.id = "32"
application.process.binary = "foobar2000.exe"
application.language = "C"
window.x11.display = ":0"
application.process.machine_id = "pij"
application.process.session_id = "1"
module-stream-restore.id = "sink-input-by-application-id:foobar2000"
Sink Input with the default output playing normally:
Sink Input #1
Owner Module: 12
Client: 3
Sink: 0
Corked: no
Mute: no
        balance 0.00
Buffer Latency: 15000 usec
Sink Latency: 5053 usec
Properties:
media.name = "audio stream #3"
application.name = "foobar2000.exe"
native-protocol.peer = "UNIX socket client"
application.process.id = "7818"
application.process.binary = "wine-preloader"
application.language = "en_GB.UTF-8"
application.process.machine_id = "beee4f833bf4e74cd586ac5e5da826d4"
module-stream-restore.id = "sink-input-by-application-name:foobar2000.exe"
Obvious difference is
vs
Hope that's a help. Let me know if you need the full print.
Thank you that's actually very useful.
For your sink,
If you restart Pulseaudio (pulseaudio -k) and don't use my plugin, is the sink latency still set that high initially or is it lower at first?
Ah, that's just because I set "default-fragments = 2; default-fragment-size-msec = 1000" a while back to try and mitigate some stutter issues I was having. Changed it to default-fragment-size-msec = 300 and your plugin's still playing skippedyquick so I don't think that's related.
Makes sense, I think the zero buffer is just because of a failure to set up the stream correctly. Would you be able to try changing to interrupt scheduling in PA? You can change it in default.pa, change the line
load-module module-udev-detect
to be
load-module module-udev-detect tsched=0
You can check it's enabled with
pactl list | grep tsched
That works!
New Sink Input with your plugin playing at normal speed.
Sink Input #1
        Owner Module: 24
        Client: 4
        Sink: 0
        Corked: no
        Mute: no
                balance 0.00
        Buffer Latency: 1974187 usec
        Sink Latency: 600895 usec
        Properties:
                native-protocol.peer = "TCP/IP client from 127.0.0.1:49614"
OK thanks, I think I have worked out the problem. You can change that option back if you prefer - it's supposed to be better but is problematic on some hardware.
New version v0.3, hopefully fixes the speed issue. I could reproduce it once but not again - it seems kind of random, so I'd appreciate feedback
Download
edit: oh no it looks like it didn't fix it >,<
Last try:
Download v0.4
I tried to test this but for some reason I keep getting "connection refused" in the log when trying to play in foobar2000.
I have followed the instructions to add the line to /etc/pulse/default.pa and rebooted but still the same. I'm on Ubuntu 20.04, any ideas?
After investigating the sped-up playback bug and looking at some similar issues from other projects, I am somewhat convinced it's a bug in Pulseaudio or certain ALSA drivers. I'd suggest using tsched=0 if you have that issue. I have left the workaround in in case it's useful, however it's behind a preference in the advanced preferences page.
This version also has some fixes to smooth out visualisations.
Download 0.5
Is pulseaudio running? Normally when an application tries to output audio, Pulseaudio is started automatically, however that won't work when using it over the network, so you have to start it yourself. You can start it by running 'pulseaudio -D' or opening pavucontrol and waiting for it to connect.
Yes, it's up and running. I can verify with pavucontrol and foobar2000 recognizes it with the default output component. It's just that when I switch the output to foo_out_pulse I get nothing.
Is there any other way I can test playing something via the native-protocol-tcp module?
Yes you can try running any other application with the environment variable PULSE_SERVER set to 127.0.0.1, eg
PULSE_SERVER=127.0.0.1 mpv test.mp3
If that works, is there any other output in the foobar console when it fails? Could you try with release 0.1 from github?
