HDMI audio doesn't start playing immediately 2020-08-02 09:06:47 I've set up my new receiver Denon AVR-X1660H to play audio from HDMI source. The chain is as follows:FLAC 16/44.1 stereo from PC HDD -> foobar2000 1.5.1 @ Windows 10 -> NVIDIA GTX 1660 HDMI Output -> Denon AVR CBL/SAT HDMI Input -> wired 2.0 SpeakersThe proble is that in foobar2000 the playback starts immediately, but the speakers start to sound after ~1.5 seconds. So I lose the first 1.5 secondsofthe audio. This happens with all sounds, including system sounds, but only when nothing was played before the current playback started, so it looks like Nvidia or Windows or AVR need some time to initialize HDMI output.Is this a common porlbem for HDMI? Or maybe I have wrong setup somehow? If it is a common problem, what could be a workaround here? I have tried Affix Silence DSP already, but it places silence at the beginning of the each track, so I can't play them gaplessly then. Last Edit: 2020-08-02 09:09:14 by Steve Forte Rio
Re: HDMI audio doesn't start playing immediately Reply #1 – 2020-08-02 10:50:38 Use foo_dsp_pregap instead of Affix Silence
Re: HDMI audio doesn't start playing immediately Reply #2 – 2020-08-02 19:41:06 Also SPDIF Keep Alive and Sound Keeper can be helpful. Last Edit: 2020-08-02 19:45:02 by Rollin
Re: HDMI audio doesn't start playing immediately Reply #3 – 2020-08-02 21:02:08 SoundKeeper is detected as a troian https://www.virustotal.com/gui/file/a5be26ee36e58707a957ab539128134d9d7727d48c9c27b0ce54c8283f58447a/detectionSPDIF Keep Alive stops working after playing audio through WASAPI exclusive. The Pregap DSP causes some glitch after prepended silence UPD: looks like Pregap works well in Noise mode. Thanks Last Edit: 2020-08-02 21:06:56 by Steve Forte Rio
Re: HDMI audio doesn't start playing immediately Reply #4 – 2020-08-02 21:29:20 Quote from: Steve Forte Rio on 2020-08-02 21:02:08SoundKeeper is detected as a troian https://www.virustotal.com/gui/file/a5be26ee36e58707a957ab539128134d9d7727d48c9c27b0ce54c8283f58447a/detectionFalse positives... Source code is available for inspection - https://bitbucket.org/veg/soundkeeper/src/default/
Re: HDMI audio doesn't start playing immediately Reply #5 – 2020-08-05 10:44:35 Quote from: Steve Forte Rio on 2020-08-02 09:06:47Is this a common problem for HDMI? Yes. The tip in the pic would expain.
Re: HDMI audio doesn't start playing immediately Reply #6 – 2020-08-05 12:11:24 One known solution is to have some app playing digital silence all the time through the offending interface. That fixed the problem with my own nVidia/HDMI rig doing exactly what you describe.The keep-alive apps linked above should help. Though you can just run any audio player looping silence.
Re: HDMI audio doesn't start playing immediately Reply #7 – 2020-08-05 18:23:24 Same here, I fixed it with Soundswitch 2.0 (by den Otter) after trying other solutions.Only thing is, when you switch sample rate or number of channels, the input device will probably mute for a few seconds to adjust. This will never happen with the default output though, only with WASAPI exclusive (optional).
Re: HDMI audio doesn't start playing immediately Reply #8 – 2020-08-06 02:16:24 I have that 1-2 second issue with AC-3 audio (5.1) MPEG video but not PCM stereo either from plain audio files via HDMI or video MPEG stereo only, no AC-3 via HDMI.G²
Re: HDMI audio doesn't start playing immediately Reply #9 – 2020-12-06 21:42:02 Quote from: Steve Forte Rio on 2020-08-02 21:02:08SoundKeeper is detected as a troianI updated the binary (added standard VC++ entry point to calm down AV software) and moved source code to GitHub: https://github.com/vrubleg/soundkeeper/
