Topic: Commas and semi-colons (Read 130 times) previous topic - next topic
Anyone know why FB2K changes semi-colons to commas in some song properties fields? It also changes semi-colons to backslashes in multiple-entry fields (genres, geographical, etc). Not a massive issue, but it does cause annoyances with MP3Tag editing. Thanks for any help...
Re: Commas and semi-colons
Semicolon is a multivalue separator in foobar2000. Behind the scenes it gets written in a format the tag standard in use defines. You see commas as separators between values when using default titleformat print syntax. You can use $meta_sep() function to print with different separators.
