Topic: 1.6 is unable to play mono and multichannel files with Default output mode (Read 450 times) previous topic - next topic
1.6 beta 7 is unable to play mono files with Default output mode if Window's setting for soundcard is stereo. Unrecoverable playback error: Unknown error (88890002). If i manually add "Convert mono to stereo" to active DSP then it works. The same problem with multichannel.
No such problems with Case's WASAPI shared component and old DS mode.
Re: 1.6 is unable to play mono and multichannel files with Default output mode
Thanks for reporting.
Should be fixed in beta 9, please test.
Also, what exact version of Windows is this on?
Nothing has changed unfortunately. Still the same error. Windows 7 SP1.
I'm also getting the same error message on mono files (Unrecoverable playback error: Unknown error (88890002)), when using the default output.
I am also using Windows 7 SP1 (x64)
I personally do not get the errors when playing mono files. My realtek audio settings are set to stereo as well. I am running Windows 10 v1909.
The problem appears to have been Windows 7 specific.
Fixed in beta 10, thanks for reporting
