Topic: [Monkey's Audio, Musepack] External Encoder settings for CUETools (Read 340 times) previous topic - next topic
Why don't the settings work
MAC.exe
- %O -%M
c1000 c2000 c3000 c4000 c5000
Monkey's Audio (MAC.exe)
and how do I encode with an external encoder Monkey's Audio?
PS: there is a great lack of encoding in Musepack
Re: Encoder settings for CUETools
MAC.exe doesn't support stdin, so IIUC it's not possible.
I'm not sure what you mean. (Without fully testing) I was able to add Musepack.
supports STDIN
Usage:
  mpcenc [--options] <Input_File>
  mpcenc [--options] <Input_File> <Output_File>
Input_File must be of the following:
  -                stdin                 (only RIFF WAVE files)
Tagging (uses APE 2.0 tags):
Close CUETools
%appdata%\CUE Tools\settings.txt (or yourfolder\CUE Tools\settings.txt if running portable)
find (the actual number of formats may differ in your settings file)
CustomFormat10AllowEmbed=0
CustomFormats=11
add new format
CustomFormat10AllowEmbed=0          <<<< use highest CustomFormat # +1
CustomFormat11Name=mpc
CustomFormat11EncoderLossless=
CustomFormat11EncoderLossy=     <<<< will be set when you add and use encoder
CustomFormat11Decoder=
CustomFormat11Tagger=1       <<<< 1 is for APEv2
CustomFormat11AllowLossless=0
CustomFormat11AllowLossy=1       <<<< Lossy format
CustomFormat11AllowEmbed=0
CustomFormats=12        <<<< increase  CustomFormats +1
save
Open CUETools
add encoder
X
select Mode before first attempt to encode
X
Please test and confirm.
korth
MPC is worked! Thanks!
MAC.exe - working. But this is old version.
