Topic: foobar freezes when changing playlist (Read 335 times) previous topic - next topic
I'm running foobar2000 v1.5.4 on Windows 7.
When I double click a playlist (stream) other than the one I'm playing foobar freezes. It take several minutes to start playing again.
What's the way around that?
Re: foobar freezes when changing playlist
Install the latest stable release, 1.5.5.
That does it. Thanks
In fact, no, it's still not working, even though it did when I first tried it.
Foobar 1.5.5 still hangs minutes when changing playlist, same as before.
Hi there,
What components do you have installed? If you make a new portable install to a new folder, with no components, does the same thing happen?
If so, you may need to follow the instructions in the pinned support thread (Appendix A-B) and post more information for developers to look at.
Cheers
I don't know what components are. I simply downloaded foobar 2000 and did a straight install on my Windows 7 system.
I used to run it on Windows 8 without any problem.
Are there any error reports in the Console? You can find the Console with View | Console
None that I can see:
Components loaded in: 0:00.048706
Configuration read in: 0:00.006821
foobar2000 v1.5.5 [standard]
Watching: C:\Users\dell\Music
Watching: C:\Users\Public\Music
User Interface initialized in: 0:00.472990
FFmpeg version: 3.4.6-0ac9001
Startup time : 0:01.150986
Opening track for playback: "http://174.36.206.197:8000/stream1"
Opening track for playback: "http://radioklassikstephansdom.ice.infomaniak.ch/radioklassikstephansdom.mp3"
Opening track for playback: "http://mediau.yle.fi/liveklassinen"
The problem occurs with "http://radioklassikstephansdom.ice.infomaniak.ch/radioklassikstephansdom.mp3". Perhaps it's because of the mp3?
There is something wrong with that file. It doesn't play here, but no freeze.
[[16:12:31] Unable to open item for playback (Object not found):
16:11:33] Minibar scanning http://radioklassikstephansdom.ice.infomaniak.ch/radioklassikstephansdom.mp3
[16:11:33] Track couldn't be analyzed
EDIT: Now it works:
[16:20:49] Opening track for playback: "http://radioklassikstephansdom.ice.infomaniak.ch/radioklassikstephansdom.mp3"
[16:20:49] Minibar scanning http://radioklassikstephansdom.ice.infomaniak.ch/radioklassikstephansdom.mp3
[16:20:49] Track couldn't be analyzed
Yes, for some reason it seems to be working now. Thanks
