Topic: How to show the value of Album Artist nothing else (Read 227 times) previous topic - next topic
My understanding is that if Album Artist is blank/null, Artist will be populated.
I have a need to update, what I believe is a small population, of Album Artist fields that contain incorrect values, usually album name, however when I display Album Artist as a column I can't see which are empty. Showing empty values will make it easier for me to sort then browse for oddball values as I generally don't use that column but some music I inherited uses that field.
thx
Re: How to show the value of Album Artist nothing else
You could also first filter the ones with or without the ALBUM ARTIST tag with Library > Search to narrow down problematic tracks:
%album artist% PRESENT
%album artist% MISSING
@Daeron, you need to omit the %% when you do that. Your query would still return tracks with artist etc.
album artist PRESENT
@snotlicker
Is 'Library/Search' different from 'Facets/Filters'?
In Facets, we need to put '%%', isn't it?
