Topic: Sorting bei Genre in Playlist of Colums UI? (Read 174 times) previous topic - next topic
Hi there,
it´s nice to be here and I hope of getting help by an issue of sorting playlists in Colums UI. It is possible to sort every Column by it´s tag (Title, Album, Date, Length etc. etc.) clicking on the Tag Field - except Genre... Is this a bug? Thank You for Your support :-)
Best
Saitenschwinger
Re: Sorting bei Genre in Playlist of Colums UI?
Genre isn't there by default (which I hadn't noticed before because I almost never use the genre tags).
Right-click on one of the existing column headers and click "Preferences" in the dropdown menu.
Preferences should open to the Columns UI page for "Columns".
Click "New" below the column list.
In the "Title " box beside the list (on the ""Options" tab), enter "Genre" (without the quotes)
In "Linked Meta Field" enter "%GENRE%" (without the quotes)
Switch to the "Display Script" tab
In the (only) box (on that tab), enter "%genre%" (without the quotes)
Hit "Apply"
You should now have a "genre" column.
d.
thank you for your help. But my question was not how to generate a new (genre) column, my question is, why it does not function to sort by gerne like in other colums. I already have a genre column. Because dex Otaku do not use genre-Tags, can somebody else help?
Thank You
