Topic: EAC 1.3 - CDDB.SDF file appears to be corrupted...can data be recovered? (Read 242 times) previous topic - next topic
Hi there all
First time posting, so here goes! I have ripped about 250-odd CD's into 1024kb/s FLAC format using EAC 1.3 [I am using Windows 10 Pro 64-bit May 2020 Edition] and it was working perfectly until this afternoon when it suddenly started crashing on startup with the message
"Unhandled exception - at 60BEAE90 -> ACCESS_VIOLATION"
After a bit of sleuthing I moved the CDDB.sdf out of the C:\Users\[USERNAME]\AppData\Roaming\EAC/ directory and EAC started up OK; move it back and it crashed (and so on)...so it was clearly the culprit
I ran EAC on another machine using the old CDDB.SDF file and the same thing happened on it too, so I'm guessing that it is either too large (unlikely) or has been corrupted :-(
Is there any way to retrieve the data in the OLD CDDB.sdf and incorporate it into the new CDDB.sdf file?
