Topic: Pixels of CD photos in playlist columns (Read 3074 times) previous topic - next topic
Re: Pixels of CD photos in playlist columns
I've uploaded an updated version which exposes %front_cover_bytes%. Note that all previously saved will be lost as I've changed the internals for how data is stored. All files will need scanning again. Also, the component now requires fb2k v1.6 or above.
https://github.com/marc2k3/foo_jscript_panel/wiki/Other-Components#foo_cover_info
edit: the breaking changes have nothing to do with exposing the file size in bytes - it was always stored internally that way. The breaking changes come from me no longer storing/checking the last modified timestamps of files. All selected files are now scanned regardless.
Thanks for the update.
How should I scan the entire music library now?
And what about the index-data: is still named "95EA6D78-0081-4080-A599-64A148BABCE5"?
@snotlicker
Thank you very much!
Can't link the function to an icon?
Thanks a lot for your time!
But I think this is not valid to scan the entire library, am I wrong?
I am sorry to disturb you, but I just asked the question above because, from what I noticed, it is only possible to scan selected tracks in the playlist, and not the complete library, as with the previous version of the component, which I use again.
Anyway, I like a lot your component. Thanks again.
