Topic: Cannot be verified as accurate EAC (Read 346 times) previous topic - next topic
Hey there, hope all you are fine
I'm new here and also with ripping CD's so i have a little question with my log file from EAC, because it's says that the 14 track of my CD cannont be verified as accurate.
Here is the log:
Exact Audio Copy V1.5 from 20. February 2020
EAC extraction logfile from 28. April 2020, 19:58
Los Prisioneros / La Cultura de la Basura
Used drive  : HL-DT-STDVDRAM GUD0N   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 102
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -e -p -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "PERFORMER=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "ALBUMARTIST=%albumartist%" -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" -T "COMMENT=%comment%" %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  1:23.02 |         0    |     6226
        2  |  1:23.02 |  3:09.03 |      6227    |    20404
        3  |  4:32.05 |  4:14.00 |     20405    |    39454
        4  |  8:46.05 |  3:48.57 |     39455    |    56611
        5  | 12:34.62 |  4:53.63 |     56612    |    78649
        6  | 17:28.50 |  4:39.12 |     78650    |    99586
        7  | 22:07.62 |  4:48.38 |     99587    |   121224
        8  | 26:56.25 |  2:17.57 |    121225    |   131556
        9  | 29:14.07 |  5:49.10 |    131557    |   157741
       10  | 35:03.17 |  4:20.05 |    157742    |   177246
       11  | 39:23.22 |  3:09.25 |    177247    |   191446
       12  | 42:32.47 |  4:37.68 |    191447    |   212289
       13  | 47:10.40 |  3:32.62 |    212290    |   228251
       14  | 50:43.27 |  8:04.23 |    228252    |   264574
Track  1
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\01 Somos sólo ruido.wav
     Pre-gap length  0:00:02.00
     Peak level 91.1 %
     Extraction speed 2.1 X
     Track quality 100.0 %
     Test CRC 404433C9
     Copy CRC 404433C9
     Accurately ripped (confidence 4)  [527AD087]  (AR v2)
     Copy OK
Track  2
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\02 La cultura de la basura.wav
     Peak level 83.6 %
     Extraction speed 2.8 X
     Test CRC 93D73B31
     Copy CRC 93D73B31
     Accurately ripped (confidence 4)  [6E76E27A]  (AR v2)
     Copy OK
Track  3
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\03 Que no destrocen tu vida.wav
     Peak level 96.0 %
     Extraction speed 3.2 X
     Test CRC 6663C37C
     Copy CRC 6663C37C
     Accurately ripped (confidence 4)  [50867DC1]  (AR v2)
     Copy OK
Track  4
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\04 Usted y su ambición.wav
     Peak level 85.1 %
     Track quality 99.9 %
     Test CRC 223BAC22
     Copy CRC 223BAC22
     Accurately ripped (confidence 4)  [69583290]  (AR v2)
     Copy OK
Track  5
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\05 Cuando te vayas.wav
     Peak level 83.0 %
     Extraction speed 3.8 X
     Test CRC 0C201E4F
     Copy CRC 0C201E4F
     Accurately ripped (confidence 4)  [B2ADADC8]  (AR v2)
     Copy OK
Track  6
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\06 Jugar a la guerra.wav
     Peak level 90.8 %
     Extraction speed 4.0 X
     Test CRC 4142055A
     Copy CRC 4142055A
     Accurately ripped (confidence 4)  [DE731819]  (AR v2)
     Copy OK
Track  7
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\07 Algo tan moderno.wav
     Peak level 92.0 %
     Extraction speed 3.6 X
     Test CRC 20AA5E80
     Copy CRC 20AA5E80
     Accurately ripped (confidence 4)  [8CD08ED1]  (AR v2)
     Copy OK
Track  8
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\08 Maldito sudaca.wav
     Peak level 96.4 %
     Extraction speed 2.9 X
     Test CRC 861B35DC
     Copy CRC 861B35DC
     Accurately ripped (confidence 4)  [186C428A]  (AR v2)
     Copy OK
Track  9
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\09 Lo estamos pasando muy bien.wav
     Peak level 85.5 %
     Extraction speed 4.7 X
     Test CRC 1F7D0EC3
     Copy CRC 1F7D0EC3
     Accurately ripped (confidence 4)  [E09AB7DC]  (AR v2)
     Copy OK
Track 10
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\10 Él es mi ídolo.wav
     Peak level 88.9 %
     Extraction speed 4.6 X
     Test CRC 278C0803
     Copy CRC 278C0803
     Accurately ripped (confidence 4)  [1E9CD152]  (AR v2)
     Copy OK
Track 11
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\11 El vals.wav
     Peak level 84.6 %
     Extraction speed 4.5 X
     Test CRC CCC9C521
     Copy CRC CCC9C521
     Accurately ripped (confidence 4)  [13381E4C]  (AR v2)
     Copy OK
Track 12
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\12 Otro día.wav
     Peak level 90.2 %
     Extraction speed 4.1 X
     Test CRC 8F5AC895
     Copy CRC 8F5AC895
     Accurately ripped (confidence 4)  [0A12D17D]  (AR v2)
     Copy OK
Track 13
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\13 Pa pa pa.wav
     Peak level 87.4 %
     Extraction speed 3.9 X
     Test CRC C6FF0A8E
     Copy CRC C6FF0A8E
     Accurately ripped (confidence 4)  [AE0F9CBB]  (AR v2)
     Copy OK
Track 14
     Filename C:\Users\Gonzalo\Downloads\Los Prisioneros - La Cultura de la Basura (1995) [FLAC] {EMI Odeon Chilena S.A. 7 98758 2}\14 Poder elegir.wav
     Peak level 82.7 %
     Extraction speed 5.0 X
     Test CRC 0031CB40
     Copy CRC 0031CB40
     Cannot be verified as accurate (confidence 4)  [C92454FB], AccurateRip returned [453A8D02]  (AR v2)
     Copy OK
13 track(s) accurately ripped
 1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
No errors occurred
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: K7qY3zDhZIAp_s51dMwSbWKP.5w-] found
Submit result: already submitted
Track | CTDB Status
  1   | (20/20) Accurately ripped
  2   | (20/20) Accurately ripped
  3   | (20/20) Accurately ripped
  4   | (20/20) Accurately ripped
  5   | (20/20) Accurately ripped
  6   | (20/20) Accurately ripped
  7   | (20/20) Accurately ripped
  8   | (20/20) Accurately ripped
  9   | (20/20) Accurately ripped
 10   | (20/20) Accurately ripped
 11   | (20/20) Accurately ripped
 12   | (20/20) Accurately ripped
 13   | (20/20) Accurately ripped
 14   | ( 1/20) Accurately ripped, or (19/20) differs in 6 samples @07:45:65
If you are sure that your rip contains errors, you can use CUETools to repair it.
==== Log checksum D93CDFC002014519D7EDE439A3CA50E165ACCA5138065AF5B62009E209481C22 ====
It would be great if someone can tell me what to do, if it's something that i have to worry about, or maybe trying to rip the CD again in another drive, i want to have a "perfect (100% acurrate)" copy of the disc. Thanks.
Re: Cannot be verified as accurate EAC
It's 6 samples about 19 seconds from the end of the track. I doubt you'd notice it.
You could try ripping the CD again in another drive or repair this rip with CUETools.
korth
Thanks for the answer, yeah the problem is that i want to get a log without any error, a 100% log. So i re-ripped the CD like 4 times now and still getting some issues, but i will still trying, thank you.
You could use paranoid mode. I had a CD where track 2 was never accurately ripped in secure mode. In paranoid mode it did. Use at your own risk though, as paranoid mode might damage your drive. With my drive: LG Slim Portable DVD Writer, model GP57EW40, paranoid mode was not a problem.
Thanks for the answers, i will try today with another external drive just for testing, btw i have a doubt with the meaning of the numbers that appears before the "acurrately ripped" on the CUETools section, because i ripped this CD like 6 times now, and i get different logs files example:
Wich is better here and why?:
This is the log of the post:
Read mode               : Secure
Quality                         : High
Add ID3 tag                     : No
Track  1
     Peak level 91.1 %
     Test CRC 404433C9
     Copy CRC 404433C9
     Copy OK
Track  2
     Peak level 83.6 %
     Test CRC 93D73B31
     Copy CRC 93D73B31
     Copy OK
Track  3
     Peak level 96.0 %
     Test CRC 6663C37C
     Copy CRC 6663C37C
     Copy OK
Track  4
     Peak level 85.1 %
     Test CRC 223BAC22
     Copy CRC 223BAC22
     Copy OK
Track  5
     Peak level 83.0 %
     Test CRC 0C201E4F
     Copy CRC 0C201E4F
     Copy OK
Track  6
     Peak level 90.8 %
     Test CRC 4142055A
     Copy CRC 4142055A
     Copy OK
Track  7
     Peak level 92.0 %
     Test CRC 20AA5E80
     Copy CRC 20AA5E80
     Copy OK
Track  8
     Peak level 96.4 %
     Test CRC 861B35DC
     Copy CRC 861B35DC
     Copy OK
Track  9
     Peak level 85.5 %
     Test CRC 1F7D0EC3
     Copy CRC 1F7D0EC3
     Copy OK
Track 10
     Peak level 88.9 %
     Test CRC 278C0803
     Copy CRC 278C0803
     Copy OK
Track 11
     Peak level 84.6 %
     Test CRC CCC9C521
     Copy CRC CCC9C521
     Copy OK
Track 12
     Peak level 90.2 %
     Test CRC 8F5AC895
     Copy CRC 8F5AC895
     Copy OK
Track 13
     Peak level 87.4 %
     Test CRC C6FF0A8E
     Copy CRC C6FF0A8E
     Copy OK
Track 14
     Peak level 82.7 %
     Test CRC 0031CB40
     Copy CRC 0031CB40
     Copy OK
No errors occurred
Track | CTDB Status
This is one of the new logs:
EAC extraction logfile from 30. April 2020, 2:39
Read mode               : Secure
Quality                         : High
Add ID3 tag                     : No
Track  1
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\01 Somos sólo ruido.wav
     Peak level 91.1 %
     Test CRC 404433C9
     Copy CRC 404433C9
     Copy OK
Track  2
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\02 La cultura de la basura.wav
     Peak level 83.6 %
     Test CRC 93D73B31
     Copy CRC 93D73B31
     Copy OK
Track  3
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\03 Que no destrocen tu vida.wav
     Peak level 96.0 %
     Test CRC 6663C37C
     Copy CRC 6663C37C
     Copy OK
Track  4
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\04 Usted y su ambición.wav
     Peak level 85.1 %
     Test CRC 223BAC22
     Copy CRC 223BAC22
     Copy OK
Track  5
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\05 Cuando te vayas.wav
     Peak level 83.0 %
     Test CRC 0C201E4F
     Copy CRC 0C201E4F
     Copy OK
Track  6
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\06 Jugar a la guerra.wav
     Peak level 90.8 %
     Test CRC 4142055A
     Copy CRC 4142055A
     Copy OK
Track  7
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\07 Algo tan moderno.wav
     Peak level 92.0 %
     Test CRC 20AA5E80
     Copy CRC 20AA5E80
     Copy OK
Track  8
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\08 Maldito sudaca.wav
     Peak level 96.4 %
     Test CRC 861B35DC
     Copy CRC 861B35DC
     Copy OK
Track  9
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\09 Lo estamos pasando muy bien.wav
     Peak level 85.5 %
     Test CRC 1F7D0EC3
     Copy CRC 1F7D0EC3
     Copy OK
Track 10
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\10 Él es mi ídolo.wav
     Peak level 88.9 %
     Test CRC 278C0803
     Copy CRC 278C0803
     Copy OK
Track 11
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\11 El vals.wav
     Peak level 84.6 %
     Test CRC CCC9C521
     Copy CRC CCC9C521
     Copy OK
Track 12
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\12 Otro día.wav
     Peak level 90.2 %
     Test CRC 8F5AC895
     Copy CRC 8F5AC895
     Copy OK
Track 13
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\13 Pa pa pa.wav
     Peak level 87.4 %
     Test CRC C6FF0A8E
     Copy CRC C6FF0A8E
     Copy OK
Track 14
     Filename C:\Users\Gonzalo\Documents\Los Prisioneros - La Cultura de la Basura (1995)\14 Poder elegir.wav
     Peak level 82.7 %
     Extraction speed 4.4 X
     Test CRC 4CCC1762
     Copy CRC 4CCC1762
     Cannot be verified as accurate (confidence 4)  [0EEABF78], AccurateRip returned [453A8D02]  (AR v2)
     Copy OK
No errors occurred
Submit result: K7qY3zDhZIAp_s51dMwSbWKP.5w- has been submitted
Track | CTDB Status
 14   | (19/20) Differs in 6 samples @07:28:44
==== Log checksum BF00024B23A50E072ACC04BBE2EABF3E96D492FCA62DC7A336DA9FAB95083D79 ====
AccurateRip can take up to 60 days to update (EAC cycle + AccurateRip cycle). CTDB updates immediately.
Submit result: already submitted <<<<<<
Track | CTDB Status
( 1/20) is your own rip previously submitted and (19/20) are rips by other people that differ by 6 samples
You've now made a second unique submission so if no one else rips this CD, your next attempt could show (1/21) by you or (1/21) by you and/or (19/21) by other people for track 14.
Both differ from other rips (that are not yours) in CTDB by 6 samples and neither match what is currently in the AccurateRip DB.
Track 14
     Copy CRC 0031CB40
Track 14
     Copy CRC 4CCC1762
korth
