Topic: Changing the date tag format on a group of Shows. (Read 119 times) previous topic - next topic
Novice here with what I hope is a simple question. I received a fully tagged collection of Jerry Garcia shows. But the Date format is different from what I use.
All the Jerry shows are mm/dd/yyyy
I want them to be yyyy-mm-dd
Is there a simple method using the properties box to do this?
Re: Changing the date tag format on a group of Shows.
Use Automatically fill values.
Source: other.
$substr(%date%,7,10)-$substr(%date%,1,2)-$substr(%date%,4,5)
Pattern: %date%
Expand the source string as needed if your tags are not completely uniform.
Thank you j7n
I just used on a sample set of files and it works great and I understand the script I think.
Now to put it to use on a set of 12,000 audio files, and take a 420 break while foobar works
