WavPack 5.3.0 Release 2020-04-17 05:41:32 This is really a pretty minor update, but I wanted to get in the fix reported here where garbage characters could get appended to imported ID3v2 TXXX tags (thanks Nejiro). This mostly applies to DSF files, but the ID3v2 import can now be used with other file types as well.Since the integration with OSS-Fuzz there have been four issues discovered and fixed, plus many more discovered locally and fixed (using libFuzzer and various Clang sanitizers). None of these were exploitable and so I don't consider them at all critical, but they are worth getting.Changes: fixed: OSS-Fuzz issues 19925, 19928, 20060, 20448 fixed: trailing garbage characters on imported ID3v2 TXXX tags fixed: various minor undefined behavior and memory access issues fixed: sanitize tag extraction names for length and path inclusion improved: reformat wvunpack "help" and split into long + short versions added: regression testing to Travis CI for OSS-Fuzz crashersAs always, the sources and binaries are available on GitHub and (somewhat less securely) on my download page.Thanks, and stay safe everyone!
Re: WavPack 5.3.0 Release Reply #1 – 2020-04-17 09:11:22 Thank you for your continued work on this excellent codec. WavPack has been my primary lossless codec for a very long time now. Thank you, again!
Re: WavPack 5.3.0 Release Reply #4 – 2020-04-24 12:27:52 Hi Bryant, I just installed Ubuntu 20.04 lts and in the repositories there is wavpack version 5.2.0-1, how do I go to 5.3.0? Or if there are no changes can I also keep these that are here?Thanks
Re: WavPack 5.3.0 Release Reply #6 – 2020-04-25 05:09:01 Quote from: Nejiro on 2020-04-24 12:27:52Hi Bryant, I just installed Ubuntu 20.04 lts and in the repositories there is wavpack version 5.2.0-1, how do I go to 5.3.0? Or if there are no changes can I also keep these that are here?ThanksHi Nejiro. You definitely do not want version 5.2.0 because that's the version that has the bug you discovered. I would suggest either continuing to use the 5.2.1 that I built and attached to the other thread, or use the 5.3.0 binaries that I am attaching here.edit: deleted binaries with libcrypto1.0.0 dependency. Last Edit: 2020-04-25 20:09:09 by bryant
Re: WavPack 5.3.0 Release Reply #7 – 2020-04-25 12:44:28 In fact I saw that it has that bug, with binaries I can't do anything about it, I remember that I had done a procedure to update but I don't remember how to do it, it seems to me that I had put files on a system folder ..... .Thanks
Re: WavPack 5.3.0 Release Reply #8 – 2020-04-25 12:58:40 Ok, I went to read the other tread and I put these files https://hydrogenaud.io/index.php?action=dlattach;topic=118619.0;attach=16269 in / usr / local / bin so I can have this version 5.3.0 what's different?Thanks
Re: WavPack 5.3.0 Release Reply #9 – 2020-04-25 13:08:43 It no longer works if I put those files on / usr / local / bin, this error comes out"wavpack -hmv --import-id3 *.dsfwavpack: error while loading shared libraries: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory "Thanks
Re: WavPack 5.3.0 Release Reply #10 – 2020-04-25 13:24:37 So, I confirm that if I put the binaries that you have released, both those of the other tread and those of 5.3.0 on / usr / local / bin the program does not work, so I must necessarily use those of the repositories of 20.04 that have the bug ...... I can use it the same is not a problem, but in 18.04 it worked, here not ......
Re: WavPack 5.3.0 Release Reply #11 – 2020-04-25 20:06:59 Sorry, I guess libcrypto1.0.0 is not standard anymore.I have created a new set of binaries without that dependency. Good luck!
Re: WavPack 5.3.0 Release Reply #12 – 2020-04-25 21:05:17 I always have to put them on / usr / local / bin right?
Re: WavPack 5.3.0 Release Reply #15 – 2020-05-20 12:07:17 Thanks a bunch, David, your work and superb CODEC very much appreciated.
Re: WavPack 5.3.0 Release Reply #17 – 2020-07-13 17:32:14 Thanks David, for such a solid, ever-up-to-date lossless/lossy format!Nilson
