Topic: Unable to built pfc project (Read 2513 times) previous topic - next topic
Thank you for deleting the other two posting, unfortunately the one with the original has been deleted too
Okay, once again :
I get this error message while compiling the PFC project with VS2k3 and the 0.7b29 SDK :
mem_block.h(189): error C2247: 'ALLOC_FAST_DONTGODOWN' not accessible because 'mem_block_t<T>' uses 'private' to inherit from 'mem_block'
        with
            T=TCHAR
Get a real compiler.
mem_block.h line 189:
mem_block_fastalloc(unsigned initsize=0) {set_mem_logic(mem_block::ALLOC_FAST_DONTGODOWN);if (initsize) prealloc(initsize);}
No matter what inheritance permissions are used, mem_block::ALLOC_FAST_DONTGODOWN is public in mem_block, and it should compile; if it doesn't, then your compiler is a worthless piece of shit.
I use a real compiler....the latest version of the same compiler you use for your development work. Come on, it shouldn't be too difficult to make the SDK compatible with 6.0/.NET and 2003, so please don't post such arrogant answers. If you want that other developers write components for your software you should stop with posting like that...
It's a very obvious compiler bug and I don't see any clean way to workaround it on my side (other than copying/moving the enum from mem_block declaration and possibly editing all code using it).
Just out of curiosity, is there a reason you're using private inheritance there, Peter?
