Topic: Blurred images in Panel stack splitter after a while (Read 1519 times) previous topic - next topic
I have a Panel stack splitter (Columns UI) that shows track info.
A while ago, at the bottom I placed a bunch of images that are greyed out or in full light
according to the value of some tags.
I noticed that this images were shown blurred, even if the originals are sharp.
I tried changing them from .jpg to .png and it worked as they we suddenly shown correctly
but now they are blurred again.
I attached the original one and a screen capture of the same size.
This is what I have in the script:
$puts(dy_imgw,$div($mul(%ps_height%,10),100))
$puts(dy_imgh,$div($mul(%ps_height%,10),100))
$puts(dy_imgp,$div($mul(%ps_height%,90),100))
$puts(imgn,14) //Defines the total number of images
$puts(bglum,40) //Defines the luminosity of the backgroud images
$puts(h1,$get(imgh)) //Defines the width of the images
$puts(v1,$get(imgw)) //Defines the height of the images
$puts(mulh2,$div(%_width%,$get(imgn))) //Defines the distance between the center of two images accordingly to the width panel
$puts(mulh1,$get(mulh2)) //Defines the distance between the center of two images
$puts(padl,$div($sub($get(mulh2),$get(h1)),2)) //Defines the distance from the left margin
$puts(btm1,$get(imgp)) //Defines the bottom position of the images
//Dimmed images
$imageabs($add($mul($get(mulh1),0),$get(padl)),$get(btm1),$get(h1),$get(v1),'.\images\Breakfast black.png',bottom,,$get(bglum))
//Full light images
$if($strstr(%situation%,Break),$imageabs($add($mul($get(mulh1),0),$get(padl)),$get(btm1),$get(h1),$get(v1),'.\images\Breakfast black.png',bottom))
Does anybody know where this come from and how to avoid that?
Re: Blurred images in Panel stack splitter after a while
Try using $drawimage instead of $imageabs.
That seems to have done the trick.
Thank you very much.
