Re: SELA v2 - A lossless audio codec with focus on simplicity and code quality
Reply #14 –
RE: dependencies, I did a search for the first file mentioned (libgcc_s_seh-1.dll) and found it in several places (python, git, gnuplot,etc).
The only place where it's in the system's environment variables seems to be gnuplot.
For python and git, the env_var paths don't lead to where libgcc_s_seh-1.dll is located.
And regarding the sampling rate, I tried with 96kHz and it spat out some error that I've seen when the wrong format is used.
Did you manage to run v2.0.1/v2.0.2? What error did you receive for the file you tested?
I'm not sure what happened, but it encodes the 96kHz file now.
v.1 and .2 encode the 96kHz wav file.
