Topic: Problem with tag mappings (Read 177 times) previous topic - next topic
Hello,
Let's say that I have a FLAC file with the following tags:
TITLESORT = a
ALBUMSORT = b
ALBUMARTISTSORT = c
ARTISTSORT = d
Now I want to convert this file to a MP3 file using foobar2000 converter.
The expected behavior would be that the tags would map as the following (according to this article in the wiki):
TITLESORT ->  TITLESORTORDER / TSOT
ALBUMSORT ->  ALBUMSORTORDER / TSOA
ALBUMARTISTSORT -> ALBUMARTISTSORTORDER / TSO2
ARTISTSORT -> ARTISTSORTORDER / TSOP
But instead I get the following tags in the new file:
TITLESORT -> TXXX/TITLESORT
ALBUMSORT -> TXXX/ALBUMSORT
ALBUMARTISTSORT -> TXXX/ALBUMARTISTSORT
ARTISTSORT -> TXXX/ARTISTSORT
As it seems the tags are remain unchanged.
Is this bug or normal behavior of the built-in file converter?
Is there is a way to map the tags correctly when converting?
I'm using version 1.5.2 of foobar2000.
Re: Problem with tag mappings
Problem noted, thanks for reporting.
