Topic: Writing your own mp3 decoder (Read 1130 times) previous topic - next topic
Not sure if this is the correct forum to ask about this.
How do you go about writing your own mp3 decoder ?
What are the resources that are out there for that ?
Can you please advise me on the starting points ?
Re: Writing your own mp3 decoder
LAME is both an encoder and decoder and the website says:
LAME is an educational tool to be used for learning about MP3 encoding.
The MAD decoder was always highly rated and is open source. You will find it and a lot of useful info and links here:
MAD Decoder
MAD Decoder
Where are you getting information about the encoding standard itself ?
I tried getting the actual standard from ISO, but its really expensive. Where do I get information about MP3 itself ?
This is beyond my programming abilities but I assume both LAME and MAD are well documented.   These kind of "bigger projects" are also usually team efforts.
Inside The MP3 CODEC has quite a bit of information, but probably not the nitty-gritty details you need.
MP3 Diags is another open source project that might be helpful.
I can only echo the above.
When I was starting out I went to a university library and borrowed a book on mpeg compression.  Once I was more comfortable with the basics, I started reading source code of existing decoders, which made a lot more sense once I understood what they were doing.
Do you remember what book it was ? Can you please tell me the name ?
Good starting point. I wish I could have got my hands on the standard.
