Topic: fooweb2020: reworked components website (Read 3708 times) previous topic - next topic
Re: fooweb2020: reworked components website
With fb2k 1.5.3 beta 4, component auto update dialog is now resizable and can present multilevel bullet lists in change logs - two spaces before the asterisk to create a nested list.
Regretfully, it seems that something is bugged with bullet lists. The following layout is displayed incorrectly:
Plain text
  • Item
    • Sub-Item
Plain text 2
  • Item
Plain text 3
`Plain text 2` and `Plain Text 3` indentation will be borked (see https://www.foobar2000.org/components/view/foo_spider_monkey_panel for example).
Another small suggestion: add a Changelog header before or after the Current version. Currently it's not very obvious that the release text is a changelog (without reading said text).
[EDIT] Another small bug, there is an empty new line appended to the beginning of the changelog when Previewed.
Change log formatting updated. Added 'change log:' header before the change log.
Not sure if this is a proper place to report this but: a few fb2k versions back there was the following change "Made possible to check for updates of components listed but not hosted on foobar2000.org.". But no matter what I've tried I couldn't force my fb2k instance to produce any notification about an available update.
Are there any specific steps required to enable this feature?
Indeed, checking for updates of components without downloads does not appear to be functional. Investigating.
Edit: Fixed
Reply #32
Yep, works now =)
v1.5.3 b5 has the same indentation bug in change log as `fooweb` though :P
Lines with no asterisk were meant to continue the previous change log line (like, additional notes for a change), rather than present headers. I'm getting that changed, so spaces before text are used to determine what the content is (two or four spaces for extra info, no space for header).
Reply #34
It would be a good moment to report any pending bugs with 1.5.3 change log formatting. I'd like to prepare 1.5.3 final, which means finalizing the change log bullet list spec.
Reply #35
Changelogs (of components that I've checked) display correctly in 1.5.3b6.
Url support (even a basic one, without aliasing) would be really appreciated though =)
Reply #36
I was using the component website tonight with a component which had been in beta with version 0.4.5b4, and I tried to officially release version 0.4.5. After publishing that version, foobar told me the component did not need an update. It was only when I bumped the version to 0.4.6 in the component registry that I could update through foobar.
Is there specific formatting I need to use for semvar comparisons, or is this currently bugged?
Reply #37
From foobar2000\SDK\componentversion.h:
//! Please keep your version numbers formatted as: N[.N[.N....]][ alpha|beta|RC[ N[.N...]] \n
//! Sample version numbers, in ascending order: 0.9 < 0.10 < 1.0 alpha 1 < 1.0 alpha 2 < 1.0 beta 1 < 1.0 RC < 1.0 RC1 < 1.0 < 1.1 < 1.10 \n
//! For a working sample of how foobar2000 sorts version numbers, see http://www.foobar2000.org/versionator.php \n
P.S. Probably the link should be changed from http to https (current browsers aren't happy when they see plain http).
Reply #38
Thanks, I'll keep that in mind next time I need to do a beta release.
Reply #40
By the way,  the default example was sorted as:
0.9.6.9
0.9.6.10
1.0 alpha 1
1.0 alpha 2
1.0 beta 1
1.0 beta 2
1.0 beta 2a
1.0
1.0.2 beta
1.0.2 beta 1
1.0.2
1.0.2.1
1.0 RC
1.0 RC55
1.1
Reply #41
Looks like the script is broken now. Sorry for linking to it.
Reply #42
Regression has been fixed, release candidates are again between betas and stable.
The versionator.php link is OK to use - it references same code as site's code matching updates so it exposes any bugs present in it.
Reply #43
Assume its an oversight on part of the author/developer, and I apologize in advance for this probably being the wrong thread to post it, but new, week-old component here w/newest version here (tag type "album art")
A foobar enthusiast who's neither an audiophile, nor an album snob.
Ever notice whenever there is a thread mentioning track ratings, someone will inevitably come in to post that they don't use ratings or believe in rating music?
Reply #44
Marc/snotlicker does not publish his components in the registry.
Reply #45
@Peter: a small bug/formatting issue - additional new lines are ignored.
Example:
Source code for the changelog:
Hotfix for 1.3.0.
Fixed
Result (mind the missing double new-line after `Hotfix for 1.3.0.`):
