Topic: [SOLVED] The 2 last characters of the resulting CUE file truncated (Read 327 times) previous topic - next topic
I have a CUE file named: (1982) Skin, Brains, and Guts (E.P.).cue
Linked to a full album FLAC named: (1982) Skin, Brains, and Guts (E.P.).flac
When I try to split per track, I use this template:
%directoryname%\'('%year%')' %album%[  '('%unique%')']
To my understanding the result must be a CUE and FLAC files located in the same directory and named:
(1982) Skin, Brains, and Guts (E.P.) (1).cue as the filename is already taken .
My issue is I the is last .) is truncated.
Result: (1982) Skin, Brains, and Guts (E.P.cue
It happens only when the album name contains .) at the end.
Where I am wrong in my template?
Here some info about original the CUE file
PERFORMER "7 Seconds"
TITLE "Skin, Brains, and Guts (E.P.)"
REM DATE 1982
REM GENRE Hardcore
FILE "(1982) Skin, Brains, and Guts (E.P.).flac" WAVE
CUETools CUE file generated:
REM DATE 1982
REM GENRE "Hardcore"
REM DISCNUMBER 1
REM TOTALDISCS 1
FILE "1.01 - Skin, Brains, and Guts.flac" WAVE
Encoding tied: UTF-8, UTF-8 and ANSI
The MediaInfo from the original FLAC file:
Album                                    : Skin, Brains, and Guts (E.P.)
Album/Performer                          : 7 Seconds / 7 Seconds
Part                                     : 1/1
Genre                                    : Hardcore
Recorded date                            : 1982
Writing application                      : reference libFLAC 1.3.1 20141125
CONTENTGROUP                             : USA
Resulting track MediaInfo result:
Part                                     : 1
Part/Total                               : 1
Track name                               : Skin, Brains, and Guts
Track name/Position                      : 01
Track name/Total                         : 9
Genre                                    : Hardcore
CDTOC                                    : 9+96+F9A+1F8A+2DF3+3695+6283+77C2+8BD7+9895+C555
Version of CUETools tried: 2.1.6 and 2.1.7
The FLAC files are generated, named and tagged correctly,
The content of the CUE file is correct.
I am using Windows 10 64bit
Usually use UTF-8 BOM for more compatibility with non-latin characters.
I am sure this is a simple mistake in my template but I cannot see it.
TIA
Re: The 2 last characters of the resulting CUE file truncated
Result: (1982) Skin, Brains, and Guts (E.P.flac
? - did you mean .cue?
So you're using
%directoryname%\'('%year%')' %album%[  '('%unique%')'].cue
so you can modify the file name of the .cue
instead of using
%directoryname%\%filename%[  '('%unique%')'].cue
korth
oops edited the post as I meant .cue yes.
Thanks is worked!
So you did notice the .cue I added to your template.
korth
Re: [SOLVED] The 2 last characters of the resulting CUE file truncated
Yes, and tested both template 8)
I was sure the .cue was implied.
Thanks I now can process 1846 albums in batch
Just don't try to do everything at once. CUETools stores some data from each rip processed until the end of the run.
korth
I do it per artist basis to be sure.
