Topic: exhale - Open Source USAC encoder (Read 322404 times) previous topic - next topic
Re: exhale - Open Source USAC encoder
Reply #175
del
Reply #176
exhale v1.0.4-63b919d2
Built on May 30, 2020, GCC 10.1.0
Binaries removed. New compile will come after Chris fix the current issue.
Reply #177
netranger's too
"ERROR while trying to open input file Z:\╟руЁєчъш\exhale v1.0.4-63b919d2\Win64\/╠єч√ър/wav/Loreena McKennitt - An Ancient Muse.wav! Does it already exist?"
Reply #178
It's an issue of the exhaleApp source code, m14u.
Chris
Reply #180
As I wrote above, I'll try to fix that for the next release. Please don't wait for that, it might take some time. Alternatively somebody else could fix it.
Chris
Reply #181
By the way, I call this release the "E" release since this is the fifth public release of exhale. E is also the initial of a former colleague of mine at Fraunhofer, a kind and gentle person and brilliant mind who passed away two weeks ago, much too young. I dedicate this exhale version to him.
Chris
Sorry for your loss, Chris.
Reply #182
As requested:
www.rarewares.org/files/aac/exhaleApp-v.1.0.4b-a7a5204a_x64.zip
www.rarewares.org/files/aac/exhaleApp-v.1.0.4b-a7a5204a_x86.zip
Intel 19 compiles.
Thank You. That was fast.
Early I've managed to run 38 hours  of music on this beta build ,CVBR mode 3. No issues were found.
P.S.  It's time for  binaries of 1.0.4 final
This release completes my general audio quality tuning for all CVBR modes. I'm not planning further major changes in bit allocation, only sample-specific adjustments if severe audio quality issues are reported (that is, for samples other than Fatboy, Girl, and Linchpin).
All right.  As for the last test@80 kbps, exhale can be very usable ( previous 1.0.3.x) even at this bitrate once Linchpin, Fatboy and equivalent samples would be tuned, hopefully, in some future. I wouldn't mind to use it at 80kbps for mobile use also when outside, driving, etc.
As for now, 1.0.4 looks solid.
Reply #183
1.0.4 Release binaries:
www.rarewares.org/files/aac/exhaleApp-v.1.0.4-63b919d2_x64.zip
www.rarewares.org/files/aac/exhaleApp-v.1.0.4-63b919d2_x86.zip
Christian: Would you like these added to the 'aac' page at Rarewares? If so, perhaps you would be kind enough to provide a suitable description? TIA.
Reply #184
Just had some time to test the v1.0.4 binaries i compiled and they work just fine in foobar2000 when converting. No issues at all.
Reply #185
They would work fine with foobar2000 converter because it changes the current working directory to the output location and simply emits a relative path to the output file, which it uses an ASCII safe temporary name for.
I can try to implement Unicode support using the same piece of code as the Windows FLAC uses. That makes it quite simple, as it implements support for both command line arguments and fopen with UTF-8 strings, and converts them to UTF-16 for Windows' Unicode API.
Reply #186
Thnx for the reply/info kode54 :)
Reply #187
Exhale 1.0.3 is settled into SBo  (the Slackware repository for 3rd party scripts) and I am preparing to update to 1.0.4. Two questions have come up though:
  • A simple 'make release'  creates two executables in bin: exhale and exhaled. At the moment I package exhale only but I am a little curious as to the purpose of exhaled? I am guessing that it a version of exhale that contains debug symbols...
  • A static library: libexhale.a is generated in lib using the simple 'make release' but how do I generate a shared library? Nothing in the Linux world will link to either static or dynamic library at the moment but shared libraries are preferred in the Slackware world. I can see references to a dynamic library in makefile.base but I am a little too obtuse to work out how to build it unfortunately...
And thanks again for a working xHE-AAC encoder  :)
Reply #188
Usually, i have no problems with using command-line encoders. But i cannot make exhale for windows work.
D:\Downloaded\exhaleApp-v.1.0.4-63b919d2_x86\exhaleApp.exe D:\Downloaded\exhaleApp-v.1.0.4-63b919d2_x86\1.wav D:\Downloaded\exhaleApp-v.1.0.4-63b919d2_x86\1.m4a
doesn't work
cd /d D:\Downloaded\exhaleApp-v.1.0.4-63b919d2_x86
exhaleApp.exe 1.wav 1.m4a
doesn't work also
Can someone give me full working example of command to use?
Reply #189
You need to provide a preset:
exhaleApp.exe 5 1.wav 1.m4a
Also foobar2000 converter preset works fine with parameters <preset> %d
Having additional question if there's an Adroid player cabable playing this format, and how goes this compared to Opus.
Reply #191
D:\Setup\Programmiportable\exhaleApp-v.1.0.4-63b919d2_x64\exhaleApp.exe  1 "C:\Users\User\Documents\1\no.wav" "C:\Users\User\Documents\1\no.m4a"
First to use mode 1, you need to resample the wav file (only format supported), you can do with foobar2000 in processing and you add the resampler.
To me it worked even if you use the same name in m4a file as the wav file.
Reply #192
Can someone confirm plentiful fails to encode 24 bit sources? I get encoded only few track of an album, while when downscaling the source to 16 bit, all tracks are converted.
Reply #193
I tried with a 24/96 file and exhale immediately failed (mode 4 if that matters). Then I downsampled the file to 24/44.1 WAV, and then exhale encoded this WAV file without issue.
On my side 24 bit seems fine, but not 96000 Hz
Reply #194
Thanks very much for the offer, that would be great! Even a PM with some quoted reference code on how to use 'wchar_t' instead of 'char' (I assume that's part of the issue) would already be very helpful, I don't have much time for this at the moment.
That's strange, 'make release' should only create exhale, only 'make debug' should create the debug build exhaled.
88.2 and 96 kHz should work from CVBR mode 5 or 6 upwards, and 24 (or even 32) bits should work in any case. Do you have a short 24-bit WAV file for me which doesn't work, to identify the issue?
Chris
Reply #195
Hi, I have been trying out exhale, and so far so good, but to make things easier I noticed exhale is apparently capable of taking input from stdin, so I had assumed I should be able to pipe to exhale from ffmpeg instead of having to convert everything to wav first?  Anyway below is the command (one of the ones I have tried anyway) I am trying to use:
ffmpeg.exe -i input.??? -f wav - | exhale.exe 5  "output.m4a"
Which isn't working, so my question is, is piping from ffmpeg possible or should I give up on this method?. And if it isn't currently implemented, could I add it as a feature wish, if it isn't already on the todo list.
Reply #196
Try to add:
-map_metadata -1 -bitexact
parameters to ffmpeg.
    AiZ
Reply #197
Thanks very much, nice to have this working.
I had actually tried the metadata flag in my trials but had removed it for simplicity of the posted version, but have never had to use the bitexact flag before, so that was the missing ingredient I hadn't tried, anyway, thanks again, AiZ.
Reply #198
Update (preset 3).
1.0.01.0.11.0.21.0.31.0.41e41f670
castanets106107100106105105
fatboy_30sec111112111115115115
eig99101102114113113
Bachpsichord106105111117121121
Enola110110108106107107
trumpet101100106105105105
applaud104106107107107107
velvet108109109107107107
Linchpin939495929393
spill_the_blood102102106108109108
female_speech10410597978685
French_Ad104104101103102102
41_30sec109110112115114114
finalfantasy10110010098104104
ATrain106106110114113113
BigYellow109110109105106106
FloorEssence105106105107109109
macabre9695100107107107
mybloodrusts9797101959595
Quizas103104107110110110
VelvetRealm106105108114113113
Amefuribana100100101105105105
Trust99100102101102101
Waiting103103106109111110
experiencia107108104101103103
HearttoHeart105105108103102102
Tom'sDiner115115102104107106
Reply #199
C.R.Helmrich, can you clarify exactly what you are seeing in the fb2k metadata writing that is corrupted, per this note?
The reason is an incompatibility between exhale's file write-out routine and foobar2000's metadata transfer routine, with the latter writing the metadata only partially and/or at the wrong location in the MPEG-4 file generated by exhale.
I'm encoding in fb2k 1.5.5 beta 1, and I'm not seeing any of these errors in the metadata; the files are still playing fine with no issues, at least using kode54's fdk-aac decoder.  If you can detail what you are seeing that is wrong, I can pass it back to Peter and he can try to fix what's wrong in the fb2k metadata writer.  :)
