Re: JScript Panel + other components
Reply #4 –
Runs main menu commands from the command line. Unlike native command line handling/foo_runcmd, this supports dynamic menu items. Also, you must supply the full path.
foobar2000 /run_main:Edit/Sort/Randomize
foobar2000 /run_main:"Playback/Device/Primary Sound Driver" << use double quotes when command contains spaces
foobar2000 /run_main:Edit/Search
foobar2000 /run_main:Library/Search
