Topic: EAC v1.4 always writes log for 2nd compressor (Read 2062 times) previous topic - next topic - Topic derived from Exact Audio Copy v1.4
Hello. The log now doubles the extraction process. Also, the log contains 2nd compressor's settings even if it is switched off.
Re: EAC v1.4 always writes log for 2nd compressor
The extraction process is not doubled.
The selection is extracted from CD to WAV once
compressed by external program
compressed by additional external program
I reported log file issue to the developer
I have a workaround: Make sure the 'Additional Filename' Naming scheme doesn't have a valid path when you're not using 'an additional external program for compression'
example
'Filename' Naming scheme: %tracknr2% %title%
'Additional Filename' Naming scheme: none\%tracknr2% %title%
korth
Thanks for reporting the issue. Yes, I meant that information about extraction was doubled in the log. Thanks for a workaround but now I downgraded to 1.3 to wait that issue to be fixed.
