Topic: No files showing from Quicksearch (Read 106 times) previous topic - next topic
Hi.
My Quicksearch is not finding files when I type into the filter bar.
I have loads of method man in my collection but yet it's not showing anything.
Example: https://hydrogenaud.io/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_104214_ba8e38408c7c43a575721282f5b3142e;topic=0
After typed in info: https://hydrogenaud.io/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_104214_8133301510f770e6209ce113339be6ef;topic=0
ANY IDEAS ON WHAT'S CAUSING THIS?
Thanks for your time!
Re: No files showing from Quicksearch
If you are referring to the 'foo_quicksearch' component, it is not visible at all on your screenshot.
You are typing into the filter section of the 'Album viewer' component instead.
The Album viewer is also showing stuff based on library structure (your music folders/file names), which does not seem to have 'Method man' in them. You can try switching the 'View by folder structure' dropdown menu to something else (like artist), assuming your music is properly tagged.
@SILENCE THA NOMAD
dat theme....can you even go further?
