Topic: foobar2000 1.51 - Japanese diacritic text problem (Read 194 times) previous topic - next topic
There seems to be a problem rendering japanese diacritical marks. In the attached screenshot a song title ends with a japanese character with a diacritical mark (it looks like ゛). The topmost rendering ド is correct, the properties window title shows ト (diacritical mark missing), and the track title in the properties window shows ト ゛ (diacritical mark too far to the right).
Re: foobar2000 1.51 - Japanese diacritic text problem
I wouldn't know how either of those could be fixed, but I'm not the right person to ask anyway. At least for Properties title and editor, it may be down to your configured font settings for the Default UI. It uses fairly standard font rendering code, so either Windows has a bug, or foobar2000 needs special handling for diacritics across the board.
Thanks, based on your suggestion I'm looking into fonts. In Preferences/Fonts, all values are set to Segoe UI. The properties window has it's own font control, after changing it's value to Segoe UI I was able to make the properties window "track title" value match the playlist window.
The value in the title bar is still missing the diacritical mark completely, do you know where the font control for that is?
Also, I compared foobar to Notepad and they match so like you said if it is a bug it's at the Windows level.
From the screenshot, I can see your default windows font in Properties window is not rendered as clear type. You can check registery, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontLink\SystemLink, see how your default font registery key is performing.
