Topic: Artifacts in Case's Smart Dither? (Read 428 times) previous topic - next topic
Original:
[attachimg=1]
Smart:
[attachimg=2]
[attachimg=3]
mda:
[attachimg=4]
[attachimg=5]
Audio files attached. Adding more bits won't eliminate the artifacts.
Re: Artifacts in Case's Smart Dither?
Thanks. I have always used Adobe Audition to verify correctness of the output and its frequency display doesn't seem accurate enough to show these issues. But I can see them with sox's spectrogram. The issue is in my output truncation function. I'll try to fix it soon.
Should be fixed in the just released version.
Yes fixed. Thanks!
Are these artifacts something to be concerned about for files processed previously to the fix? I am talking about 24 bit > 16 bit with 1 bit dither noise. Would you recommend to redo these or is this more of a cosmetic error which will be inaudible in practice?
Proverb for Paranoids: "If they can get you asking the wrong questions, they don't have to worry about answers."
-T. Pynchon (Gravity's Rainbow)
No need to reprocess. The noise was only introduced with 23 and 24 bit output. And its loudness was under 130 dB below digital fullscale. I'd claim it was inaudible.
