Topic: Nothing happens when I try to open CUETools (Read 174 times) previous topic - next topic
Trying to open CUETools on 64-bit Windows 10, already tried fiddling with compatibility settings and using the compatibility troubleshooter. Tried redownloading CUETools, tried different versions, tried adding it as an exception in my antivirus, tried updating and restarting the computer, also tried running as administrator with all of these other attempts to fix the issue still nothing. All that happens every time I try to open it, I get a little loading circle for a second and then nothing happens no dialog box saying what the problem might be, just nothing.
Re: Nothing happens when I try to open CUETools
Read here please (2nd sentence).
Regards, ...
CUETools.exe is dependent on other folders and files. Make sure you unpack the entire zip file.
You downloaded from here?
Also have a look at
https://hydrogenaud.io/index.php?msg=959968
korth
